Which oil pump?
Started by RECHRGD, March 06, 2016, 09:22:15 PM
charge70
Before you put the new pump on the motor,did you open it up and check for debris inside.The last melling oilpump I installed still had machining chips inside.You may have a stuck relief valve,take it off take it apart and see.It may be fixable without purchasing another pump.
RECHRGD
Quote from: myk on May 09, 2016, 06:13:25 AM
You're running the hardened intermediate shaft right?  BTW my oil pressure does the same: reads at 40-50 psi no matter what's going on, and that's with a separate oil pressure gauge doing the monitoring...
Not sure.  It's the same one that ran the HV pump.  Seeing that I'm going back to another HV unit I'm not worried about it.....
13.53 @ 105.32
RECHRGD
Quote from: charge70 on May 09, 2016, 08:59:56 AM
Yes I did, it was clean.....
13.53 @ 105.32
cdr
Quote from: RECHRGD on May 09, 2016, 02:35:32 PM
did you read my private message?
BSB67
Quote from: RECHRGD on May 08, 2016, 06:10:54 PM
Quote from: BSB67 on May 08, 2016, 04:59:27 PM
Why did you change the pump in the first place?
Does the new pump have a standard or high pressure spring?
What was the idle oil pressure with the new, and the old high volume pump?
My pressure dropped considerably and wouldn't come back up.  I put the car away for the winter and went back to deal with it in the spring.  On the first startup the pressure went right back to normal.  After posting here, the general consensus seemed to conclude that the pressure relieve spring must have stuck open and somehow reclosed over the winter or startup.  Never having dealt with these pumps before, I just decided to buy a new one.  I got the standard volume melling pump based upon comments from the members.  With the old HV pump I would usually idle at 40+ lbs.  at highway speeds were 60+.  The new standard pump would maintain 50 regardless of rpm, until yesterday's drop to 40.  That's my story and I'm sticking to it........
Okay.  So at an idle, the standard pump had 50 psi and now it has 40 psi at idle.  If that is the case, you don't need a HV pump.  Just a different spring.
11.68 @ 120.2 mph
rockdogg2020
Is it a MUST to use the Hardened Shaft when using the HV Pump?
68CoronetRT
Quote from: rockdogg2020 on May 12, 2016, 05:33:14 PM
No, but it is suggested. You loose that end and your oil pressure is gone.
