1969 Charger project
Started by INTMD8, January 21, 2018, 02:38:55 PM
INTMD8
Didn't realize this was still active, thanks guys I appreciate it.
At first it was easy to induce tire spin with the Avons -but- they were brand new and it was rather cold out (upper 40's)
After a few updates the car now makes 650/510 at the tires.
The video is when it was colder.  Now with some more miles on the tires and temps in the 70's the traction is amazing. I'll have to get a new video but it hazes them through first and hooks up great in 2nd and up.
https://www.youtube.com/watch?v=hv_g7E3SSsg
https://www.youtube.com/watch?v=JsUsL0YLLXE
INTMD8
Almost forgot, had new wheels made for the new tires as well.
70 sublime
INTMD8
Charger-Bodie
love the wheels and especially the tire tread
INTMD8
Thank you, I like the vintage looking tread as well. The tires are working great and hook up amazingly well. Not quite as good as a drag radial but closer to a drag radial than a normal street tire.
INTMD8
Next up was trying to improve aerodynamics/airflow management.  There was some good info on aerowarriors. Old factory documents of nascar testing.
I started with blocking the grilles.
Then made a lower air dam.
Then a shroud to direct all lower airflow into the radiator and block the sides so the front end can't fill up with air and act as a big parachute.
6T8440
Great workmanship and good luck with your design.
It will be very interesting to review the field results. :popcrn:
Driving through the towns and neighbourhoods that are us.
INTMD8
Thanks!
I finished it up and took it for a test drive today. It was 86deg today and coolant temp was the lowest it's ever been, by a small margin, even compared to cooler weather. Temp gauge photo was after driving it around for an hour.
E85 certainly helps however.
WHITE AND RED 69
That's a sweet setup. I would have thought blocking the grill would hurt the airflow but with that it has nowhere to go but to the radiator. Any issues in traffic?
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
