clutch size
Started by taxspeaker, May 01, 2018, 06:41:16 PM
taxspeaker
69 daytona, 440-4 barrel all stock. Blew 50 year old original clutch this weekend. Haven't pulled it apart yet, so looking for recommendations on manufacturer and size. After 50 years do you think I should also replace flywheel? Engine is stock and runs great without leaks or oil issues, so just pulling tranny.
thanks
BLK 68 R/T
I'd just have it surfaced and check it for cracks. Clutch should be the 11" 18 spline. If you like the original style with the stiff pedal feel then stick with the 3 finger style. If you want a lighter pedal then ditch the heavy spring from the clutch pedal and go with a centerforce dual friction diaphragm style.
taxspeaker
XH29N0G
That has also been my experience. Resurface and checked for cracks. Have always wondered when they wear out.
Or maybe it protects us.
Quote from: taxspeaker on May 01, 2018, 06:41:16 PM
Even if it's resurfaced and shows no cracks it's still a cast flywheel. Billet is always better.
Quote from: John_Kunkel on May 02, 2018, 12:26:16 PM
:iagree:
Spend the money on a good flywheel, your legs will thank you.
DAY CLONA
Quote from: c00nhunterjoe on May 03, 2018, 12:15:17 AM
:iagree:
Agreed, no reason to use a factory flywheel (even NOS) with what's available in the aftermarket and SFI approved, your going to pull everything down, now's the time to upgrade
