cam break-in
Started by mbandit, September 15, 2005, 11:15:50 AM
MOPARHOUND!
GM's E.O.S. (Engine Oil Supplement) for $4.95 (note the description/application):
http://www.sdpc2000.com/catalog/1016/products/584/GM-Engine-Oil-Suppliment-EOS-16oz-Bottle-.htm
Had a long drawn out post on the old site on this subject.  An oil guru on Moparts posted in a thread, where I gleaned most of my info.
Modern oils have zinc reduced, IIRC, to around 300 parts per million, racing oil around 600, whereas E.O.S. is like 5-6000 parts per million.
The bottle labeling is GM's "speakeasy" way of keeping the EPA happy.  Supplement or Break-In Lube?.....Hmmmm........
I used the entire bottle on break-in of my last cam, and use a half bottle at oil changes.  Do them myself so I don't mind a few dollars for the insurance, especially since my last two cams died (one with 0 miles, and one with 9800 miles).
1971 Charger R/T, 440 H.P., Auto, A/C Daily Driven (till gas went nuts).  NOW IN CARS FOR SALE SECTION: http://www.dodgecharger.com/forum/index.php/topic,48709.0.html
1969 Charger 318/Auto (latest addtion): http://www.dodgecharger.com/forum/index.php/topic,31948.0.html
*Speed costs money son, how fast do you want to go, and for how long?"
*"Build the biggest engine you can afford the first time."
*"We normally wouldn't use a 383 for this build, parts and labor for a 440 cost the same."
doechsle
 The zinc is supposed to be harmful to catyletic (spell check) converters. This is one of the reasons it was mandated to be removed from pass. car oils. This may also shed light on why the GM bottle says not to use it every oil change. My car has no converter.
The common roller lifters today make it less needed as well.
