cam advance & timing
Started by 0X01B8, September 02, 2007, 11:09:36 AM
0X01B8
hypothetical question.  let's say you have two identical motors but one with the cam advanced 4*.  would you expect the advanced motor to want more, less, or the same initial timing than the other?  thanks.
-john
aifilaw
slightly more initial timing, but less than 4* for certain.
advancing a cam does many many things, but one of the main things it does is shift the entire powerband backwards down the RPM scale.
'72 B5 Metallic Blue Hardtop
