DodgeCharger.com Forum
November 20, 2008, 10:42:45 AM *
News: Please remember: this is the place to discuss Chargers - NOT the place to discuss politics. Political posts will be locked or deleted at the Moderator's discretion.
   Home   Help Search Calendar Login Register
Pages: 1 ... 9 10 [11]   Go Down
  Print
Author Topic: Re: just contemplating my build... [UPDATED: 4/2/08] - ALL DYNO #s  (Read 5973 times)
joflaig
Full Member
Offline Offline
'69 Dodge Charger R/T General Lee
« Reply #200 on: March 26, 2008, 06:11:30 PM »
Just a quick update, the engine is at a 2nd shop sitting on the stand for dyno. The builder does not have a dyno and it is just as well because the shop where it's at is probably the most respected in the region (though they specialize in Chevy) and I want to get some independent validation.
Anyway, they said the motor sounded great and the timing was right, but after running it for a bit to warm it up the pipes started turning red. They suspect it's running lean. The dyno pull set for today was called off. They are going to mess with the carb tonight and hopefully tomorrow or Friday do the pulls. They also installed the 1" carb spacer.
The guy at the shop who built the motor wanted to come over to this place during the dyno for final dial-in, but this guy is hated by a lot of other builders (among others) and in the end I could not get him "invited". I can only assume this is why the carb might have been running lean. But I am trying to fugre out when he broke in the motor if it's possible that he could have done any damage. The guy at the dyno shop checked the tempature on all the exhaust tubes and they were the same, which he said was a good sign...something with the valves. Of course, in break in you are only running at lower rpms and typically for a short period, 20 minutes. Am I being too paranoid here? While I had a professional experience with the engine builder, in this area some people hate him and some people use him all the time. I'm sure I should not worry, but it's just on one fhose little things that makes me a bit nervous. I'm sure in any small metro area various builders have strong likes and dislikes amongst each other and the same goes for their customers.
Logged
joflaig
Full Member
Offline Offline
« Reply #201 on: March 28, 2008, 05:24:39 PM »
Ron, You hit the nail on the head! 2thumbs You said 540 hp and 600 fpt, and guess what? On the second pull we hit 543 and 612 fpt! First pull was 530/587. Redline was 6000rpm.
It was an awesome experience to be in a small room like that with this power and noise just shaking the walls and air itself especially when the thing hits 6000rpm. It sounded incredible, like a nascar motor screaming. Below are some videos I took. I wish the sound qualitiy were better, but you can get a taste of it.
Warming up (6mb):
http://www.johnflaig.com/GL/dyno1.avi
2nd Pull (12mb):
http://www.johnflaig.com/GL/dyno2.avi
They managed to richen up the mix and cut the exhaust temp down by 250*. He said I should bring the car in and put it on their chasis dyno when it's all put together so it can be more finely tuned.
Anyway, I'm happy! I can't wait to drive this thing, but it won't be for another 6-8 weeks I bet. The track may even be open by then. I guess the 1/4 is the last test.
As for the all the NUMBERS they're putting together a booklet for me which I will get and scan and post next week. They said the engine ran the way you would hope, so I guess I won't be too paranoid now that another builder has been over it thouroughly.
Logged
NMike
Full Member
Offline Offline
« Reply #202 on: March 29, 2008, 11:20:38 PM »
love the waterpump drive! 2thumbs
i can't wait to make a very similar motor for my car.
Logged
joflaig
Full Member
Offline Offline
« Reply #203 on: April 02, 2008, 12:27:44 PM »
Here's the full results on this build!
http://johnflaig.com/GL/dyno/Page1.pdf
http://johnflaig.com/GL/dyno/Page2.pdf
http://johnflaig.com/GL/dyno/Page3.pdf
http://johnflaig.com/GL/dyno/Page4.pdf
http://johnflaig.com/GL/dyno/Page5.pdf
As I mentioned the dyno shop is a chevy place. They don't think it's a big deal, but looking at the #s they seemed to think I could have more "snap" from the motor. They thought the cam timing might be off or possibily a retarded cam.
At any rate neither they nor they guy at the resto shop thought I should be to concerned especially if there is a slight problem and it is only robbing a few horses.
But really, I am not the expert here so you guys tell me!
I still don't understand why the motor was running such a hot exhaust when it was delivered to the dyno shop. They had to mess with the jets to fatten it up. I was told the number was 12.5:1 at the top of the pull and the exhaust temp was now running 900* - 1000* after warming up the motor on the stand (What is normal?).
Basically, I think the dyno shop probably made it slightly too fat because they had more concern about getting the exhaust temp down. Their point was we can better tune it on the chassis dyno with everything hooked up. Again, they know chevy, but not so much mopar so I don't know how that factors.
I need to call the engine builder for something unrelated, and I was told to ask them if they checked the cam timing during the build. Can anyone think of anything else intelligent I could ask.
I am now back in paranoid mode.
Ron, where are you, man!
Logged
Global Moderator
Old Timer
Offline Offline
446 street/strip bullet
« Reply #204 on: April 03, 2008, 10:09:53 AM »
Very nice  2thumbs It made right around what it should  be making given the mild cam and slightly worked E-Heads.  2thumbs
I'd be happy with those power numbers.  Wink
Logged
68 Charger R/T street/strip bruiser, 70 Charger R/T 440-6 cruiser. Firecore 50 authorized dealer ; contact me with your needs
Global Moderator
Old Timer
Offline Offline
« Reply #205 on: April 03, 2008, 10:24:32 AM »
Just got home from Vegas (late last night) from the Mopars at the Strip show.  icon_smile_big
John, those numbers look fine. You have to remeber that this is a very mild build for a 512 ci stroker. You wanted a streetable engine with lots of low end power and this is what you got. Look at all the torque at low engine speed !  icon_smile_big
Even if the cam was retarded a few degrees it wouldn't make any appreciable difference. It's fine  Wink
The EGT's seem a little high. It's possible that the engine is pulling some air in from the manifold or carb base which could be leaning out the mixture. On the back of the Street Dominator Intake there is an EGR port with two holes that need to be blocked off with freeze plugs...was this done ? How much vacuum was the engine pulling at idle ?
Logged
joflaig
Full Member
Offline Offline
« Reply #206 on: April 03, 2008, 10:42:38 AM »
I figured you were somewhere warm.  Wink
No, I ain't complaining at all about the #s it makes. I am very happy with it and it's just what I wanted.
The dyno shop installed the carb spacer, I suppose it's possible they didn't torque it down enough, or there could be a vacum leak. The engine builder thought maybe the were using outside cold air on the dyno instead of the air in the room. I will check it out next time I visit my car at the shop. At any rate, it's going back on the chassis dyno for fine tuning when it's all put together.
I am definetly re-assured now. Thanks for your help on all this Ron!
When I am getting ready to go to the strip I will be asking for more advice! Can't wait to drive this thing in a month or so.
Logged
73charger528cid
Junior Member
Offline Offline
« Reply #207 on: April 03, 2008, 05:46:03 PM »
THATS GREAT!!!!  2thumbs
makes me feel good just completed my build on my engine it's very similar to yours and those # are pretty good hope mine does as well.
mines a 528  with 11.6 comp Its got flat tops with zero deck I had to run a .051 gasket to drop the comp because the block was decked the last build.
same heads Im running 1.6 rockers with a 241/247 @ .050   110 lobe sep
TM7 manifold 2" spacer  1090 king demon
mancini raceing exsternal single pick up oil system
180 gph electric pump and 1/2" fuel lines
Everything else is pretty much the same I have no acssess to a engine dyno so if I even come close Ill be happy.
Bill
Logged
Mfr426
Senior Member
Offline Offline
« Reply #208 on: April 03, 2008, 06:47:05 PM »
I am just about to finish my VERY similar 440>512 stroker motor and hope to have it to Ray Barton to break it in and get me dyno numbers in the next few weeks. All I can say about this thread is HOLY LOAD this is too cool!  yesnod
Ron, I may name my third born after you-even it's another girl!
 icon_smile_big\
Thank you both for taking the time to post the specifics, it's a real learning experience.
Mike R in Reading PA
Logged
joflaig
Full Member
Offline Offline
« Reply #209 on: April 03, 2008, 06:54:30 PM »
I am just about to finish my motor and hope to have to to Ray Barton to break it in and get me dyno numbers in the next few weeks. All I can say about this thread is HOLY LOAD this is too cool!  yesnod
 icon_smile_big
Three cheers for Ron, that's for sure!
Mfr426, I see you are from Reading. I lived for time when I was little outside of Reading in a town called Gouglersville...not far from Maple Grove. In the summer you could here them racing for miles around.
Logged
Mfr426
Senior Member
Offline Offline
« Reply #210 on: April 04, 2008, 05:32:18 AM »
Jofaig, I know PRECISELY where Gouglersville is. The NEW 222 road now really has the town on the map! I'm in Sinking Spring. Talk about small world!  Wink
I have a good friend that lives off of Maple Grove road and on some weekends their widows shake!!!! It's too bad that Maple Grove has missed Marketing 101 because that place could be a HUGE success. It's a hidden jewel and with the right owners it could be far more successful.  yesnod
I'm eager to run my car at "the Grove" this summer. I'm not going to beat it too badly but I'm eager to "try" the new motor.  drool5
Logged
Pages: 1 ... 9 10 [11]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.064 seconds with 16 queries.
