DodgeCharger.com Forum
November 21, 2008, 07:41:11 PM *
News: Please remember: this is the place to discuss Chargers - NOT the place to discuss politics. Political posts will be locked or deleted at the Moderator's discretion.
   Home   Help Search Calendar Login Register
Pages: 1 [2]  All   Go Down
  Print
Author Topic: New rack and pinon from unisteer at sema  (Read 875 times)
NorwayCharger
Full Member
Offline Offline
WWW
« Reply #20 on: January 30, 2006, 10:51:28 AM »
http://www.bigblockdart.com/index.php?topic=1620.0
More info..
Logged
AKA as the drummer boy
http://www.pink-division.com
CHARGER_FAN
Old Timer
Offline Offline
Undercover Charger
« Reply #21 on: January 30, 2006, 03:37:13 PM »
is there any word if they are going to re-design it so it mounts on the front of K-member?
If they mount it in front of the K-member, they will have to completely change the way the tie rods connect to the spindles too. That will drive the price even higher...probably about doubled, depending on if there are existing parts to retrofit, which I doubt.
Logged
The Ghoul
Senior Member
Offline Offline
« Reply #22 on: January 30, 2006, 10:42:12 PM »
im in for a grand.
My plans were to just get one of the new quick ratio manual box for the simplicity, less engine drag, and header clearence.. but it would fit better into the whole G-ride concept if I could keep wide meats on the front and still be able to steer. I like it... I hope they can be used on 3rd gens.
Logged
Silver R/T
Old Timer
Offline Offline
1968 Dodge Charger R/T
« Reply #23 on: January 30, 2006, 10:48:31 PM »
will have to wait till someone actually tries it with headers
Logged
Like the tiger, you can see his stripes but you know he's clean...
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
If you don't have the best-you're just running with the rest
Silver R/T
Old Timer
Offline Offline
« Reply #24 on: February 01, 2006, 01:14:47 AM »
Ive sent them an email, we'll see what they reply
Logged
2001 Ram 2500 CTD
Blakcharger440
Senior Member
Offline Offline
« Reply #25 on: February 05, 2006, 06:28:25 PM »
Heres another dumb question about this setup....How is that going to save weight??? The only thing being removed is the steering box,but you just added a whole rack and pinion setup to the mix and to me it looks to be even heavier than the box itself...so you are adding weight.     Huh
Logged
1970 Charger RT 4spd
1970 Charger 500 FC7
1970 Roadrunner 4spd,airgrabber
Oh yeah...shhhhhhh......69 Camaro
Mike DC (formerly miked)
Old Timer
Offline Offline
« Reply #26 on: February 06, 2006, 01:57:08 PM »
Those rack & pinions are definitely lighter than the factory steering box.
The factory PS box is something like 30 pounds (not including the factory steering linkage, which is substantial too).  But a R/P might not be half that.  The gearing hardware is smaller overall and the linkages going out to the spindles are tiny.  Even the outside of the setup is cast aluminum instead of iron.
Here's a thought:
Is there an off-the-shelp R/P that would work on a Mopar?  With all the modern cars out there now, there are TONS of these things being produced in various sizes.  Seems like there would be something that might fit right.
And the Unisteer ads say their steering ratio is 17:1 (whereas the factory PS ratio is 16:1).  Which makes me wonder if they might really be selling us an off-the-shelf steering rack with some brackets & hoses added.
Logged
dkn1997
Old Timer
Offline Offline
Long Island, NY
« Reply #27 on: February 06, 2006, 09:56:31 PM »
you might have hit it on the head there.  If you can weld, does not seem too hard to make those brackets.  I suppose somebody will at some point just sell the brackets for those that can mount them to a rack and source all the little parts.  sort of like scarebird brakes. they sell you just the bracket and parts list and you get the rest as opposed to ssb  or others who sell you a 600 dollar kit.
Logged
"Hey, Flintstone....If you play with a hot piano, you get your fingers burned"
CHARGER_FAN
Old Timer
Offline Offline
Undercover Charger
« Reply #28 on: February 07, 2006, 12:04:43 PM »
iagree Just need a little hotrodder ingenuity here & you're set. Not every cool thing needs to be available in a "kit". Wink
Logged
Steve P.
Global Moderator
Old Timer
Online Online
« Reply #29 on: February 16, 2006, 02:26:00 PM »
As most of us know pictures lie like hell. Many of us have learned this the hard way. I have looked this unit over and read what is available and my humble opinion is simple.
Yes, it will be lighter than a factory power steering system.
Yes, the ratio will make it feel better.
Yes, it will be cool to be able to say, my 60's muscle car has rack and pinion steering..
HOWEVER,,,, until they put the rack in front of the "K" member and get rid of any and all clutter that causes problems with oil pans, headers, starters, frame strength and ground clearance for all of the formentioned, I think this is just smoke and pretty paint...
Mopar did a pretty damn good job of building this front end. It has lasted many years without much hassle. I personally don't like the "AFT" steering design. I understand why they did it, but it takes away from having a large low profile oil pan. I grew up dodging the pot-holes of upstate New York. Skinny little 14" tires were little help for your K's and controll arms..... flame
Logged
Steve P.
NPR, Florida
Silver R/T
Old Timer
Offline Offline
« Reply #30 on: November 22, 2006, 08:57:21 PM »
so this was one of the abandoned projects?
Logged
2001 Ram 2500 CTD
Steve P.
Global Moderator
Old Timer
Online Online
« Reply #31 on: November 22, 2006, 10:06:03 PM »
I just found it on their site. Says they are PROUD TO ANNOUNCE the b body r/p, but they have NO PIC.  I guess they aren't THAT proud!!   rotz
Logged
Steve P.
NPR, Florida
dkn1997
Old Timer
Offline Offline
Long Island, NY
« Reply #32 on: November 22, 2006, 11:37:25 PM »
If you are interested in this setup, read this first:
http://www.dodgecharger.com/forum/index.php/topic,20457.0.html
Logged
Pages: 1 [2]  All   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.053 seconds with 15 queries.
