Superbird Jacks
Started by WINGIN IT, July 30, 2011, 03:34:44 PM
WINGIN IT
What are both Superbird jacks going for these days?
Are they the same as Daytonas?
Is one harder to find than the other?
Is someone reproducing these?
nascarxx29
When I had authentic ones they went for $3000.The repos are alot less .The superbird uses a black color and daytona red .But the jacks are the same.
Wingnut 426 on here makes a nice repo scissors jack
NEW EXACT Reproduction
Daytona & Superbird Scissor Jacks
These quality made jacks are all new, not from modified aftermarket jacks. Correct stamped steel base and top plate, fine thread "Acme" thread, rivet heads, locating "knob", etc. Available in red for Daytona & black for Superbird. Limited supply, Made in U.S.A.
More Images: Image 1, Image 2, Image 3, Image 4, Image 5, Image 6
$760
http://www.tonysparts.com/newproductsB.htm
1969 R4 Daytona XX29L9B410772
1970 Coronet RT WS23UOA224126
WINGIN IT
So both jacks were the same ?  Meaning 2 of the same jack for each car.
nascarxx29
The front scissors jacks were the same except for colors on the daytona its red and superbird jack is black.The rear bumper jacks were the standard bumper jack for 68-70 charger.&70 satellite road runner for the Superbird :Twocents:
WINGIN IT
ok thanks for clarifying. ;)
ksquared
OK, maybe this is an obvious newbie question that's been answered before, but if the actual original Daytona/Superbird jacks were actually original Custer Mfg. Co. Jack Model # J30, and were modified by Creative Industries somehow, why can't a supply of the Model # J30 jacks be found and modified just as was done by Creative Industries?
62 Max
Quote from: ksquared on July 31, 2011, 12:49:41 PM
And just where would expect to find a supply of jack's manufactured 40 + years ago  ?  ???
nascarxx29
The original jacks are a show correct detail  :Twocents:.I know of many original owners who wouldnt use that jack.They prefered a bottle jack instead .Or have long since sold the car.And still have the jack if they can dig it out
http://board.moparts.org/ubbthreads/showflat.php?Number=5641151
Redbird
I don't have an original Daytona Jack, and I have never put a dozen Superbird jacks next to a dozen Daytona jacks. That said I have put a couple of Superbird jacks next eachother and both are the same. I also have 2 other jacks that I am pretty sure were manufactured by Custer, and 2 more jacks that are very similar and could be Custer jacks. The Superbird jacks are slightly different than all the others. Everyone talks about the pitch of the screw, the obvious difference. Also different are subtle differences like thickness of the top plate and width of the side bars and slight differences in the pins that go through. Custer seemed to have a press or something that could press the top plate in different thicknesses, maybe for different lifting ratings? The bottom plates I have all seem to be the same, with a little zig here and there on the pressed out metal, leading me to guess that Custer had a standard form that cut the base out of flat stock. The original base plates all have little imperfections in the metal cuts in the same place. Differences in side bar width could have to do with weight rating, or just an odd match going down the assembly line.
The handle seems to be one of a standard handle they used. I have found exact handles matching my Superbird handles, exact. My thought is that they were a standard item they had by the case, certainly way more than the 2500 they needed for the winged cars. They also had a similar handle about .010 thicker in bar width, that used the exact same center piece, but has slightly different lengths of metal rods. This similar handle also has almost a 90 bend where the Superbird jack has about a 45 degree bend, these handles must have been for a slightly different use.
The Superbird hold down plate is a 1 car use item. I've never put a reproduction next to my originals. I believe there are several reproductions of these done over the years. Pictures I've seen show some to be an obvious reproduction. Like anything, when you have an original, it makes it easy to put next to something someone has for sale for comparison.
I know others know a lot more about this than I do.
I think it would be interesting to put 25 Superbird and 25 Daytona jacks next eachother, to see if there were subtle changes along the way, especially given the months difference in car production.
maxwellwedge
There were definitely at least 2 different bearings used.
nascarxx29
Jims car is a early daytona with omitted wing braces .Did it have a jack .Or was it different in the scissors jack development from the rest due to early production :Twocents:
nascarxx29
Red jack is the original from a 606 SPD daytona .Other jack was knock off for Superbird conv
62 Max
Original jack,plate and handle
nascarxx29
A friend came across of this similar appearing jack and got it for me at a flea market.To see if I think it would be a candidate for a wingcar .
Would require some mods .
hotrod98
I bought a Blackhawk model 67201 scissor jack on ebay and converted it to use in the Daytona clone that I built. It's similar but I had to make a few mods. Its good enough for a clone in my opinion. Seems like I paid $45.00 for the jack and handle.
Normal is an illusion. What is normal for the spider is chaos for the fly.
Charles Addams
Redbird
The green jack and red handle, if one just paints it red or black that is about the amount of effort it should get if it is like similar ones I've seen. Check the the handle. The ones I've seen similar to that have been 1/2" too long on the jack side and too short on the man side. Much better bottom plates can be found, it would be a lot of work to convert the base. Good for a clone. Much too easy to find a closer replacement though.
maxwellwedge
Quote from: nascarxx29 on July 31, 2011, 06:06:02 PM
Yes Dave - It has both jacks.
nascarxx29
Quote from: maxwellwedge on August 01, 2011, 07:31:25 AM
R4 Daytona SE w/ 6-pack coming up for auction
« Reply #94 on: February 23, 2009, 08:54:55 PM » Quote
Quote from: nascarxx29 on February 23, 2009, 08:13:56 PM
Did you find the headlight engravings.what about the area showing no wing braces.Is there a wing washer and bolted brackets or holes on the trunk floor for the supports
Hi Dave,
No engravings found. Here are 2 pics on your other 2 questions......pics slowly sneaking out....
Did the Doc daytona ever recieve any magazine exposure to date
maxwellwedge
Naw - Mopar Action is ready to do it but the car isn't ready for them yet.
It is going slower than Hemigeno's car did..... :lol:
hemigeno
Quote from: maxwellwedge on August 09, 2011, 10:52:42 AM
Should I laugh, or (pretend to) be insulted?
:lol:
hemi68charger
Quote from: hemigeno on August 10, 2011, 11:10:24 AM
:lol:
na......... as they say, "Some things are better slow"... Perfection..............
Houston Mopar Club Connection
maxwellwedge
:lol:
:lol:
No insult intended. Just that these things always drag on longer than we think they should. And it is not even a total resto. AB is correct - slower is usually a good thing!
hemigeno
Quote from: maxwellwedge on August 10, 2011, 11:57:02 AM
Oh, I understood that the whole time - no offense taken for sure.  That shoe [things always drag on longer than we think] not only fits, it goes with my outfit.   :icon_smile_blackeye:
