Has anyone tryed This
Started by MikeD, October 17, 2012, 11:42:09 PM
bill440rt
Right, the little canister provides enough reserve to stop the car safely, about 3 additional stops.
After that, from what I was told with the Wilwood M/C I'm running it would equate to stopping a car with regular manual brakes.
1970Moparmann
Quote from: MikeD on October 17, 2012, 11:42:09 PM
  HOW PREPPED HYDRAULIC BRAKE ASSIST UNIT
http://www.classicperform.com/Store2/Brakes/CP3003.htm
I have a Hydroboost on my 68 and out of everything I did to the car, this by far was the #1 upgrade I did.  Even better than the 5 speed.  Just my  :Twocents:.  :2thumbs:
rebby
Quote from: bill440rt on November 15, 2012, 07:30:12 AM
FWIW, some hydroboost setups utilize an internal reserve (ie: no "little canister"). Just know what you're buying and be sure whatever you go with has some sort of reserve.
Curt Rebelein, Junior
1969 Charger R/T SE (500 Stroker/833/D60 w/XP VIN)
1969 Charger (440/727/8.75, GL Project)
MikeD
OK now here is the???? of the day which brake set is the best one for this unit.
WHITE AND RED 69
What size wheels are you running? Baer and wilwood have sets that fit 15" wheels and have big sets for 17" and up. Dr. Diff also sells some cobra caliper kits for a good price. Good thing about the wilwoods is they fit the drum spindle. I have a set of wilwoods with a 10.75" rotor on mine right now and they work great with the hydroboost. A 100 times better than the old power booster. But I do feel that the small rotors struggle with size and weight of the car so I am planning on going to a Baer kit with big calipers and 13" rotors in the spring.  :cheers:
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
WHITE AND RED 69
Quote from: 1970Moparmann on November 15, 2012, 08:40:58 AM
Totally agree. Just knowing that you can make your car handle a quick emergency stop is worth the price. But a 5 speed would be soooo nice. I cant wait to get out of the slow lane on the highway.
bill440rt
Quote from: WHITE AND RED 69 on November 15, 2012, 04:43:15 PM
You'll love the bigger 13" kit with the hydroboost. The 6-piston Wil's with the hydroboost are awesome.  :yesnod:  Very positive feeling for sure.
WHITE AND RED 69
Quote from: bill440rt on November 15, 2012, 10:47:51 PM
Hey Bill! Glad to hear you like the Wilwoods. I have been going back and forth between the Wilwoods and Baers. Have you had any complaints with your setup?
MikeD
Iam running on 15" wheels. I have been looking SSBC, Wilwoods, also some sets from PST, I can not go to crazy the hydrboost is going to be about 1100.00 everything include, Iam also drop the front and redoing that.Iam going to check out this Dr. Diffbut from what I see I going to been spending  about 800.00 to 1000.00 for the brakes.
Thanks Mike
bill440rt
Quote from: WHITE AND RED 69 on November 18, 2012, 12:37:23 AM
Once I got everything dialed in, no complaints here. I liked the fact that I did not have to swap spindles, either.
I had a few bugs. The rear calipers were leaking fluid. I thought they were bad, sent them back & it turned out to be just assembly lube. They must have used a lot, because they were dripping for a while. Put them back on & they were fine. Also had a leaky bleeder screw (they are a two-piece job). I bled the brakes for a long time to get all the air out. I must have over-tightened the bleeder & got a leak. Had to order a replacement. Real minor stuff.
I think it's a real nice system. Way better designed than the SSBC crap I had. It works really well with the hydro boost.  :yesnod:
:cheers:
MikeD
Quote from: MikeD on November 18, 2012, 01:54:12 AM
What size wheels are you running? Bear and wilwood have sets that fit 15" wheels and have big sets for 17" and up. Dr. Diff also sells some cobra caliper kits for a good price. Good thing about the wilwoods is they fit the drum spindle. I have a set of wilwoods with a 10.75" rotor on mine right now and they work great with the hydroboost. A 100 times better than the old power booster. But I do feel that the small rotors struggle with size and weight of the car so I am planning on going to a Baer kit with big calipers and 13" rotors in the spring.  :cheers:
OK Guys now it is time to order the brakes I would like to use 11" rotors, its between Bear and Wilwood can you guys tell which setup you are ruining also if possible the part number to the KIT
Thanks Mike
