Warped Plastic Grill
Started by Sendero, February 18, 2006, 10:04:49 AM
Sendero
Some time ago ( old DC site) I posted a inquiry to repair a warped Grille ( 1970 ) . The general consensus was to use COLD. Basically to clamp the effected area flat with ICE COLD bars to shrink the plastic. In this specific case it had no effect. So I assume a metal bar glued to the plastic will forcibly strighten it out. Does anyone know of a glue that will bond to the plastic and metal? If you have a different idea..I am all ears.
daytonakid
Hi, I've straighten many plastic parts with heat. You need to be careful not to melt or burn it. Sometime a large heat lamp like a body shop would have to heat it when hot straighten it out hold it somehow in the postion you want it cool it or let it cool. Might take a couple times but I think you'll be surprised at the results.  Also 3m's 8115 will bond metal and plastic. Bill
Owner East Portland Auto Body www.eastportlandautobody.com
I've also straightened my grille with some heat.
It was a SLIGHT correction.  I used a normal hardware store's heat gun (the kind of thing used for stripping house paint).  It was nerve-racking, but it worked.
