Door switch connector
Started by chargd72, April 26, 2013, 12:47:29 PM
chargd72
Does anyone know where to get a new one of these connectors?  One of the 3 prongs broke off.  It's for the driver's side door switch.
ODZKing
Try calling Bill Evans (Evans Wiring)
chargd72
I emailed Bill and just got a response. They don't carry anything like that.
Anyone else?
ODZKing
Hey 72, I am a bit confused.  If it is the driver door switch, 2947844 - it should look like this.
Maybe you can clarify a bit exactly what it plugs into.   :shruggy:
chargd72
I assure you, it is the rarer three prong version. I pulled the door jam switch to check. It was mostly used in 71 e bodies but some others from 71-74 got it too. I'm on my phone so I can't provide a link but if you Google image mopar 3 pin door switch you will see what I'm talking about.
chargd72
Here is a what the switch looks like.
chargd72
A better pic.
sorry, no...
you can change it out to dual prong, simply splicing together two of the wires on one female spade terminal and then the yellow wire onto its own female spade terminal and will work the same... if you don't care to change that of course
would check on 71 diagram which exactly could be spliced together... I think black and yellow traced
the one what keeps alone is the dome circuit
HOWEVER, being handy, It is posible to restore the broken prong ;)
ODZKing
Well, for our cars the part number you are looking for is 3488435 , front left 3 terminal.
According to parts voice these places have it:
Brad Nos Parts/Westcolumbia Chrysler
WEST COLUMBIA, SC 29171
Silke's Auto Parts Inc
    JACKSONVILLE, FL 32217
CollectorsAutoSupply.com
    OROVILLE, WA 98844
Atlas Obsolete Chrysler Parts
    Murrieta, CA 92562
I would contact Silkes ... he is VERY reasonable and ships SUPER fast!
chargd72
Thanks for the leads King.  If I can't find it through one of your guys I'll probably just do as Nacho mentioned and fix it myself.  I could find a donor prong to stick in there and hit with a piece of solder.  Was just hoping to get a new piece.
71charger_fan
I just ran into this today myself. First I've ever heard of a 3-prong door jamb switch. I ordered one off of Ebay before finding out that Challengers and Chargers take a different 3-prong switch. I did find an NOS Valiant 3-prong switch which takes the same part nr as a Charger. This was after buying an NOS 2-prong switch assuming that's what I needed. Should have researched old threads on here first. Could've saved about $40.
two threads sizes on these switches, either to 2 prongs or 3 pins... everything depending on body.
the 2 or 3 prongs setup is actually year related.
as I mentioned YOU STILL CAN USE the 2 prongs kind on a 3 pins assembly, just cutting and splicing two of the wires on one prong ( if you don't care to modify that ), and the other one on the other one. Thats how laters models with 2 prongs were made, being spliced on terminals to 2 prongs switch
