1968 Backglass trim color
Started by will, July 15, 2013, 08:00:37 PM
will
I'm changing the interior from the common green to the pearl white interior. Is the backglass trim supposed to be pearl white or plain? I also need  to know what color to paint the a pillar moldings. Does anyone know who repops the trim section that comes up from the floor to the rear windows, above the sill plates? Thanks.
cdr
all the ones i have seen had black dash,carpet,headliner & the door panels & seats are white.  but i am sure somebody will say different.
cdr
here is a 69   it is charge69
will
That's great. You don't have a shot of the back glass trim, do you? btw this is for a 68, thank you for the pic.
The trim around the windows is the same color as the headliner, in this case I believe it will all be black.
68 RT
68 has diffrent white combos, white/blue, white/black, white/red, and white/green. All will have white headliners with the rear window trim in white.   :cheers:
will
Thanks guys, that's great! I found white windlace at megaparts usa and that the trim pieces are supposed to be white. Thanks for all the help! :cheers:
