Trans leak, 727.
Started by cudaken, September 08, 2013, 07:37:36 PM
cudaken
 OK, drove the 68 Road Runner around the block for the first time in 8 years last Friday. There has been some white smoke coming from the right side of the car from the headers. Not a lot so I was hoping it was from junk that had collected over the years.
When Jim and I got here down the driveway and flat Jim, check the ATF in neutral (In Park it showed only a quart low) and she was 2 and a half quarts low. So we topped her off and around the block I went.
Half away around I pulled her down to first and guess I hit around 2000 Rpm's and white smoke started to puke out of the right side of under the car. It had a oily smell so I am guessing it is ATF.
My guess are.
1 Dipstick O ring has failed.
2 Trans pan gasket.
Besides a cracked case, what else is on the passenger side of the 727 that could leak?
If I have to drop the pan, I want to run a cleaner through the 727 first to get any varnish that made have formed out first. Cooter what would you suggest? I will all so drain the converter.
You can see some of the smoke when sitting in this video. When I give some gas you can see it coming up from under the hood on the right side by Allen (41 Husk)
http://s83.photobucket.com/user/cudaken/media/She%20Lives/MyThumb_zps99e065e2.mp4.html
Not a lot and does not seem to be water!
Oh, fluid was still bright red when I checked it and after the first drive.
Thanks for the coming help!  :2thumbs:
Cuda Ken
I am back
ws23rt
It could be the front seal :shruggy:
I have a 68 sport fury that was doing the same thing so I parked it.  That was 1989.  I will get to it when I can.
Geez that was a lot of help.  Well maybe when you find out what your leak was all about It will help me. :2thumbs:
will
I had the same problem, o-ring. Could also be the neutral switch, it's on that side.
neutral switch is not on passenger side...it's on the drivers side.
cudaken
Quote from: A383Wing on September 08, 2013, 09:11:00 PM
That was what I was thinking.
Where is the vent?
          Ken
I am back
vent should be on top....but it's been so long since I have seen one, I'm not sure now
The vent is located inside the bell housing.....when fluid leaks out of the vent it will exit at the bottom of the bell/inspection plate area.  :yesnod:
The seals have contracted over time so maybe with some run time they will come back. Lucas sells a trans conditioner that will also expand the seals so that might be worth a try. Another thing to remember is that trans fluid expands when hot so try and check your level with the engine/trans up to operating temp. I've seen 1 qt difference hot vs cold. You might have overfilled the trans Ken.  ;)
cudaken
Thanks for the answers folks.
Ron, in the video I posted the Road Runner had not moved yet and in park and fully warmed up it was showing a quart low.
I will try some of the Lucas treatment and see what happens.
On the Dipstick Tube O Ring, is a special O Ring, or any type of O ring that fits is fine?  :scratchchin:
Any suggestions on what to flush the trans with if I change the filter?  :shruggy:
Ken
I am back
Road Dog
We talking quarts or pints?
If your wheels ain't spinn'n you ain't got no traction.
cudaken
Have no idea yet, only drove her a 1/4 mile.
Ken
I am back
