Seat Belt Retainers
Started by Voss, October 27, 2013, 05:22:01 AM
Voss
I am in the process of putting back original seat belts in my '68 Charger. The car (will) have shoulder belts and the front / rear lap belts.
The shoulder belt clips to the retainer at the sunvisor when not used. But what about the front and rear lap belts? Did these clip to any retainer when not used and where should the retainers be located? I have heard different opinions about these being standard from factory or not.
  had always assumed they were standard factory equipment , but think it has been mentioned they were an option , on non R/T models ,   :shruggy:  i'm no expert !! I await to be corrected  :cheers: :cheers: :2thumbs:
http://www.megapartsusa.com/proddetail.asp?prod=102%2DSB2B
I think they are standard.  An option maybe on the 70 XH cars?
Those were standard equipment on all '69s AFAIK  Not sure about 68 or 70
Voss
Found them on the front seats!  :2thumbs:
None on the rear seat? Maybe they are broken off...  :shruggy: Should it be a "2 + 1" retainer for the rear seat?
green69rt
I just checked mine and found none.  is there a picture of the mounting points or is there one in the FSM, didn't find one?   I got the point on the visor but nothing else.  Thanks guys.
Voss
Quote from: green69rt on October 27, 2013, 11:35:11 AM
I can get pics on my front seat belt retainers and post here. Haven't figured out the exact position for the rear ones. Will check the rear seat frame and see if I can figure it out.
I should have pics somewhere too of the placement but I'll need to search for them.
green69rt
I looked on my seats and couldn't find any holes or other indication of retainers or their mounting points.
charger490
i had them on my 68 charger that i bought new and i think they were atatched to the front of the rear seat. i have this one left if anyone wants it.  charger490
Lord Warlock
The retainer clip was mounted to the right side front face of the seats in the front.  Mine did not have retainers on the rear seats, or if they did, they were removed before i bought the car.  Once i put new seatcovers on, you couldn't tell where the clips would mount unless you knew where they were before.
when i said right side, i meant the right side of the drivers seat,  the passenger side probably was on  left side of the seat nearest the buddy seat or console.
moparfan53
Quote from: Voss on October 27, 2013, 04:31:49 PM
Here is pic of my '69. I put the retainers back in the original position after replacing the seat covers. Maybe it will help.
green69rt
Anyone got a pic of the front seats??
Voss
Great pic on the back seat retainers.
I can take pics on my front seats next time I am in the garage, probably on Saturday.
Ah yes, I forgot to put those on my list.  I'll have 3 point retractable belts up front but am keeping the rear lap belts so I'll have to get a set of them retaining thingies.
dodgedarren
I could use a picture of the front seat retaining clips as well for the front seats. I took them of when I dismantled the car but I have the seats installed now and I cant seem to locate where they clips mount.
bill440rt
I think he's talking about a 68.
bill440rt
Right.
I just saw '70 referenced so I was responding to that.
I know '68's had them, Chris confirmed '69 as well.  :cheers:
Lord Warlock
My 69 had them on the front seats, but they weren't on the back seat when i got the car in 1978, and it was 100% stock when i got it.  Possible someone removed them from the back seat, but i didn't see any holes in the vinyl.
Could have just been missed at the factory too.
dodgedarren
Yes. 68. I cant seem to locate the ho;e to remount these.
dodgedarren
Lord Warlock
I think he meant he can't find the hole in the seat where it attaches.  If you've recovered the seats it may be hard to find.
