pulling the dash
Started by tucknroll, January 04, 2014, 06:22:46 PM
tucknroll
man did I open a can of worms! I thought I would peek behind the dash to check a bulb and the next thing I know, I got the whole dash out. I thought I would clean it up since it's out. I know this would be no big deal to some of you but I'm still a beginner. wish me luck of getting everything back.
tucknroll
alright my first question. are there 2 extra bulbs in the dash? I have 2 bulbs that you turn to pull out and they are in a harness with no wire running to them and it looks like there never was a place for a wire to connect.
what year ? is it a charger ?
tucknroll
 is there any chance  you could take a picture !! its difficult to figure out whats happening with out actually being there , especially  dash stuff
,  these are the only pictures I have on my computer now , its of a 68 , but basically the same  , cant you see anything in these  ?
there are 3 bulbs ( capless )  that have no wiring going to them they  twist into the printed circuit board
forget where I saved this pictures from  ,  :cheers: :cheers:
tucknroll
on that bottom picture! that's the 2. why don't they have anything going to them? how do they work?
PC board, they get the current from the copper tracks in that green board.
tucknroll
thanks! that was driving me crazy.
XH29N0G
I pulled my dash apart for the first time a few weeks ago too.  All ended up being OK, but I had, and am still having a few connection issues with gauges connected to the printed circuit board.  The connections sometime are made and then sometimes they become disconnected.  The fix is pretty obvious, there are nuts that make the connection with the board that can be wiggled.  If it keeps up I may as about conducting paint.  I just thought I would mention this because you may run into the same problems.  This also applies to some of those bulbs.  The multimeter is a big help.  Other big helps are the information on clusters posted on the forum.
Or maybe it protects us.
tucknroll
when I pulled it out, I didn't disconnect the battery at first and the wire running to the alt gauge hit metal and sparked. now im trying to put everything back but im not getting any power to the car. I checked the fuses in the glove box and they all look good. whats happening?
ACUDANUT
tucknroll
is there a way to crank and drive it with the dash out so I can take it to a friends house for help?
Quote from: ACUDANUT on January 05, 2014, 12:43:29 PM
A in-line fusible wire ?
that's what i'm thinking  , have a look under the hood , for this below  , blue fusible link wire  , may well have burnt / fused
you can run with out the instrument cluster in , but you need to bolt the black & red thick amp gauge wires together , & make sure they are well insulated & not touching any metal , that  goes for all the disconnected wires back there from the disconnected instrument cluster ,
would not advise doing anything until you have  gone through all wiring &  seeing why there is no power !!
XH29N0G
Do you have a wiring diagram (like in the factory service manual)?  I had never looked closely at the diagram or the wiring, and am not electrically inclined, but I found that after some reading and matching, I could trace out the diagram to the car and  vice versa.  The only reason I bring this up is because it is a way to track down where things go on either side of the firewall.
tucknroll
I see that blue wire. now how do I check it? with a test light?  also, is connecting the red and black hotwiring? is that safe?
XH29N0G
If you don't have a multimeter, I would consider getting one.  I don't think it needs to be expensive (but others might suggest otherwise).  I think the test you would do would be for continuity (ohms) through the wire (others can pipe in if I am wrong).  My guess is that if a fusible link is blown that it will no longer be continuous.
I know nothing about connecting the other wires.
If the link popped you won't need a meter to check it.  Just feel it with your fingers and if it seems all flimsy like there is no wire in it then it's junk.  It should feel like there is wire in some of it but if it popped there will be a section that is gone and it will be like its just insulation there.
It's also possible that you smoked the guage itself.
The circuit board is old and will need some work to be reliable again.  Mine did the on off thing as well.  You can buy a new board but I cleaned mine with some isopropyl alcohol and acetone for the bad spots.  The pins felt tight until I gave them a gentle twist and 3 became loose.  I put a dab of solder on all pins to secure them to the board and now my resistance readings are as they should be.  Hopefully I don't bust anything come installation time.
tucknroll
im going to give it another shot tomorrow and need to know if I can and how to lower the steering column? I don't want to pull the whole thing out if I don't have to because that's just one more can of worms.
tucknroll
also, other than the thick black and red wires going to the amp meter, I have only 2 more wires that I don't remember where they go. they have ends on them like the black and red wires. I'm guessing maybe the oil and gas gauge?
XH29N0G
I don't know enough to know how different my 70 is from yours.  I did notice on the wiring diagrams that were posted on the links that it looks like they have the colors and the connectors posted to the various gauges and switches.
For the 70, the gas, oil, and temp were on a single plug.  The separate ones went to the wipers and washer (several went there) and the ammeter (but the ammeter had different connection from the others).  It looks similar on the A version wiring diagram that was posted.
tucknroll
the two wires I didn't know I think are a the owner before me way of bypassing 2 of the missing poles on the circuit board that are missing. could that be? if your looking at the back, its the 2 from the left.
XH29N0G
Let's hope someone pipes in who knows the answer.
Looking at the diagram posted by tan top, it looks like there should be 5 wires going into that plug, orange, black, dark blue, violet, and gray.  They are labeled as running the instr lights, volt limiter,  gas, temp and oil.  If the colors match, then I would think you have it figured out.
tucknroll
I now know how everything goes back. my problem now is when the battery is hooked up and I use a test light, nothing in the dash is showing power. I bolted the red and black wires together and still nothing. any help please?
