DodgeCharger.com Forum
January 20, 2022, 02:31:43 AM *
News: DodgeCharger.com decals are available here!
   Home   Help Calendar Login Register Chat
Pages: [1]   Go Down
  Print
Author Topic: Pop's 440  (Read 10185 times)
heyoldguy
Full Member
Offline Offline
« on: January 05, 2014, 07:09:54 PM »
Pop built a 440 for his truck back in '97.
.030" over 440
9.5:1 compression
L2355 pistons
Stock rods ARP bolts
Performer RPM intake
800 cfm Edelbrock
His ported 452 heads 2.14/1.81 valves
260H Comp hydraulic cam
1.6 Crane Gold Race rockers
483 LB-FT @ 3400 rpm and 404 HP @ 4800 rpm
He installed it and stood by the living room window looking at the truck. Said, "I got it the way I want it and now I won't get to enjoy it." He died weeks later. I inherited the truck and drove it briefly and parked it.
My son is working a set of 346 factory iron heads using the stock 2.08/1.74 valves and wanted a dyno mule (we'd been talking about one for awhile) to test them and some other ideas, and wondered what to use.
Well hey, what about Pop's 440?
We pulled the engine outta the truck.
So off came the 452 heads and on went the 346's.
Out came the 260H and in went a XE285HL.
The 800 cfm Edelbrock went back in the box and an 850 Mighty Demon went on.
Flycutting the pistons deeper and the 94.4 cc chambers of the heads gave us 8.9:1 compression.
Results as of yesterday, 498 LB-FT @ 3,600 rpm and 496 HP @ 5,400.
More to come hopefully.
Logged
Old Timer
Offline Offline
« Reply #1 on: January 06, 2014, 06:58:04 AM »
Funny how people (and other animals) just sometimes know.
Anyway, that is an interesting combination with the compression ratio and all.  Very good results from what looks to be a very streetable package.
Logged
heyoldguy
Full Member
Offline Offline
« Reply #2 on: January 06, 2014, 08:44:31 PM »
Removed the Edelbrock Performer RPM and installed M1 single plane.
RPM...........TQ/HP
3000........424/242
3100........423/249
3200........427/260
3300........452/284
3400........477/308
3500........480/320
3600........479/328
3700........488/343
3800........488/353
3900........485/360
4000........479/365
4100........477/373
4200........480/384
4300........488/399
4400........498/418
4500........503/431
4600........497/435
4700........490/439
4800........493/451
4900........504/471
5000........499/475
5100........493/478
5200........495/490
5300........499/503
5400........493/507
5500........482/505
5600........469/500
5700........465/505
Logged
Kern Dog
Old Timer
Offline Offline
« Reply #3 on: January 06, 2014, 08:50:49 PM »
I see in this case, the M1 was worth a handful of HP and torque. Good to know. Thanks!
Logged
heyoldguy
Full Member
Offline Offline
« Reply #4 on: January 07, 2014, 07:49:59 AM »
Running a box stock M1 single plane. Lift the carb and put a 2" HVH 4 hole SuperSucker on the M1 and drop the carburetor back on.
RPM..............TQ/HP
3000............428/245
3100............439/259
3200............457/278
3300............467/294
3400............478/310
3500............488/325
3600............492/337
3700............502/353
3800............492/356
3900............490/364
4000............485/369
4100............487/380
4200............489/391
4300............494/404
4400............507/424
4500............514/441
4600............507/444
4700............509/456
4800............512/468
4900............512/478
5000............512/487
5100............502/488
5200............504/499
5300............510/515
5400............505/519
5500............495/519
5600............480/511
5700............474/515
Time to pull the heads again and maybe install some real valves.
Logged
justcruisin
Senior Member
Offline Offline
« Reply #5 on: January 07, 2014, 02:44:23 PM »
How much vacuum are you pulling with that xe285hl cam, I was considering running the xe284h but am not sure if it will run my brakes. I currently have the xe275hl in a 10.2:1 440, it pulls 13" @ 900 rpm and 16" down the road.
Logged
heyoldguy
Full Member
Offline Offline
« Reply #6 on: January 07, 2014, 06:08:47 PM »
On this engine it's only about 8" @ 800 rpm and 11" @ 1050 rpm.
Logged
heyoldguy
Full Member
Offline Offline
« Reply #7 on: January 14, 2014, 08:48:21 AM »
Made a pull with the hydraulic lifters (zero pre-load cold), 2.08/174 valves, then switched to 2.08/1.81 and solid lifters (.005" hot lash).
RPM.....1.74 TQ/HP..............1.81 TQ/HP
3100.........444/262..................436/257
3300.........478/300..................468/294
3500.........496/330..................493/328
3700.........500/353..................499/351
3900.........486/361..................510/379
4100.........482/376..................507/396
4300.........485/397..................498/408
4500.........484/415..................491/420
4700.........476/426..................483/432
4900.........485/452..................485/452
5100.........478/464..................493/478
5300.........486/490..................486/491
5400.........485/498..................494/507
5500.........474/496..................493/517
5600.........437/466..................484/516
5700......................................468/508
5800......................................453/501
5900......................................446/501
6000......................................438/500
6100......................................429/498
Because we didn't make one change at a time it's only conjecture but I attribute the difference at the bottom rpms to exhaust valves and the upper rpm changes to mostly the solid lifters with some exhaust influence. Many tests left to go but I don't think I want to switch back to the hydraulics so we may never know.
Next tests will be with the solid lifters and the 346 heads with 2.19/1.81 valves flowing:
lift...........I/E
.100......81/60
.200....158/125
.300....210/176
.400....247/211
.500....274/232
.600....295/248
.700....303/257
This certainly not our best effort with this style of head as the 2.14 valves produced almost the same results. But the flow differences will still let us get some direct horsepower/flow comparisons with this type of build.
Logged
heyoldguy
Full Member
Offline Offline
« Reply #8 on: January 15, 2014, 08:40:52 AM »
Same as the test above with the M1 and 2" spacer but with the larger valves.
3000..........410tq/234hp
3100.............417/243
3200.............436/266
3300.............459/288
3400.............478/309
3500.............476/317
3600.............484/332
3700.............492/347
3800.............503/364
3900.............501/372
4000.............505/384
4100.............501/391
4200.............502/401
4300.............499/409
4400.............503/422
4500.............499/428
4600.............496/435
4700.............506/452
4800.............507/463
4900.............517/483
5000.............518/493
5100.............516/501
5200.............511/506
5300.............517/522
5400.............522/537
5500.............515/540
5600.............503/537
5700.............489/531
5800.............471/520
5900.............466/523
Logged
Global Moderator
Old Timer
Offline Offline
572 street/strip bullet
« Reply #9 on: January 15, 2014, 09:44:12 AM »
That's a very nice gain Jim....those heads are moving some serious air  2thumbs
Logged
heyoldguy
Full Member
Offline Offline
« Reply #10 on: January 28, 2014, 07:30:12 PM »
Made two pulls today with the EZ heads and the Racer Brown Roller from 1967. 544 LB-FT and 655 HP
Logged
Challenger340
Old Timer
Offline Offline
Better to be a "has been", than a "never was"
« Reply #11 on: January 29, 2014, 10:48:56 AM »
This is GREAT !!!  2thumbs
Sounds like you are having a lot of FUN with this Engine !
Logged
Only wimps wear Bowties !
heyoldguy
Full Member
Offline Offline
« Reply #12 on: January 29, 2014, 05:51:02 PM »
Great deal of fun. Two more pulls between other projects this morning. 552 LB-FT and 658 HP. Just enough time to check plugs and see that the carburetion is way lean but not dangerous. Gotta pull the engine off the dyno and get ready for a guy's 496 BB Chevy tomorrow. Then we go back to Pop's 440 with the XE285HL using the EZ heads.
Logged
heyoldguy
Full Member
Offline Offline
« Reply #13 on: April 03, 2014, 07:46:41 AM »
So, EZ heads and XE285HL. 548 TQ and 585 HP @ 6000 RPM. 500 TQ 3500-6000 RPM. The big heads keep the horsepower going and twice we shut the 440 down at 6500 RPM where it was 595 HP.
Logged
rednuck
New Member
Offline Offline
« Reply #14 on: April 08, 2014, 12:27:50 PM »
How much porting have you done to the EZ heads? or are they fairly stock for testing and just waiting for you guys to do your magic on them.
Logged
heyoldguy
Full Member
Offline Offline
« Reply #15 on: April 08, 2014, 01:17:32 PM »
The EZ heads have great deal of work done to them. Way more head than the 440 needs. 2.25/1.81 valves, full Max Wedge port size, 347 cfm @ .600" lift. They match the flows of our Victor heads that made 845 HP on a 500" wedge normally aspirated with a single 4bbl. We wanted to see how a big head would effect the little 440. What did kill power on the 440 was when we used an Indy 3X manifold and a 1140 cfm Dominator with the EZ heads.
Logged
cdr
Old Timer
Offline Offline
Katy,Tx
« Reply #16 on: April 08, 2014, 07:40:22 PM »
QT. FROM HEYOLDGUY,,What did kill power on the 440 was when we used an Indy 3X manifold and a 1140 cfm Dominator with the EZ heads.
i am assuming the indy 3x was ported to max wedge also.  & what intake worked best ?
Logged
68 Charger 512 cid,9.7to1,Hilborn EFI,Home ported 440 source heads,small hyd roller cam,a518 trans,3.54 gear,11.04@123,4100lbs on street tires full exhaust daily driver
111 by Charlie Keel, on Flickr
heyoldguy
Full Member
Offline Offline
« Reply #17 on: April 09, 2014, 07:02:38 AM »
Because of the size of the ports in the heads and what I have on hand I only had two options. What I used was an Edelbrock 2495 Victor ported to near max wedge with a 850 Mighty Demon and the 3X/Dominator combination. The Demon makes good top end power but struggles with air/fuel ratios in mid range. The Indy 3X starts life a very tall Max Wedge port with a plenum you could park a motorhome in. An Indy dual plane would have been nice to test but I must use what I have on hand.
Logged
cdr
Old Timer
Offline Offline
Katy,Tx
« Reply #18 on: April 09, 2014, 07:18:19 AM »
THANK YOU for the reply  2thumbs
Logged
MagnumForce
Junior Member
Offline Offline
« Reply #19 on: April 16, 2014, 09:37:42 AM »
Hi i am building a similar motor and i noticed that you put a mechanical secondary car with a single plane intake. Are you running a auto or a manual transmission? I have a 727 and i am not sure that intake and carb setup would work with it.
Logged
If You Ain't First, You're Last!!
heyoldguy
Full Member
Offline Offline
« Reply #20 on: April 16, 2014, 06:17:11 PM »
Similar to which configuration of this engine? A quick answer is, for street use you are generally better off with standard port heads, a dual plane and vacuum secondaries.
Logged
MagnumForce
Junior Member
Offline Offline
« Reply #21 on: April 17, 2014, 06:35:36 AM »
Similar to the engine with the cam swap after you pulled it out of the truck, thanks for the quick response, i had a feeling that would be the case. Will your engine see much street use?
Logged
heyoldguy
Full Member
Offline Offline
« Reply #22 on: April 17, 2014, 01:26:01 PM »
There is so much going on around here right now we're not sure what to do with this engine. We just got a 1974 shortbox half ton and thought it might make a good shop truck if we put the iron heads back on Pop's motor and put it in that 3.55 geared, 4-spd, half ton. Then there is the '73 Charger that is waiting for a motor.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.063 seconds with 17 queries.
