door latch
Started by el dub, May 16, 2014, 11:47:36 AM
el dub
So, do I have something backwards. Is my inside door handle spring assy. backwards. I don't remember seeing the spring. I am also wondering what went in the 2 extra holes in the lower door panel above the two screw holes for the armrest? thanks. lw
ODZKing
Got the correct armrest?   :shruggy:
Longer is what I would suggest
yea...you got the wrong armrest on there..should be the 13" one
the 2 other holes are for the alignment pins on the plastic base.
can't see your entire pic at the top, but looks like you got a 9" armrest on there
el dub
Thanks ODZ. Someone should have said, '' put the base on first dummy. ''  :rofl:
Lord Warlock
actually the plastic base covers the spring, as shown in the 2nd photo.  but the spring shouldn't show, its next to impossible to install it wrong, although a short armrest might not cover the spring, I don't think the rear armrests would fit the same  holes as the longer fronts.  the handle should sit up against the armrest.
