Something seems off..
Started by comet_666, June 26, 2014, 08:16:08 PM
comet_666
Dash pads seem to have way to much gap between glovebox pad and middle piece. I know dash is broke but I don't think it's throwing it of that much.
Definitely off, is that the dash frame that was always in the car?
moparnut
Looks like the glove box needs adjusted. Some of the screws allow for up and down movement.The others allow left and right adjustment.  moparnut
comet_666
I'll try the adjustment thing. Dash is the one that came out of the car but needed some TLC so it may be messed up.
Yes, its a little nasty isn't it?
comet_666
Yah, we had to kind of remake it, came out good but still needs TLC. Do they make aftermarket shells?
Not that I've ever heard of.  You should be able to find a good used one though.
bill440rt
Used dash shells are out there. Just make sure to find one for your model year, & a rallye dash. Standard dash frames are different. I've been told the ignition lock openings are different between '68 vs '69. And '70's had the ignition lock on the column.
To me it looks like your center pad is either warped or crooked vs the glove box door, which appears to be straight & not warped or bowed. You can try carefully tweaking the back metal from on the center pad to get it to fit better. It might be a compromise adjusting each to get them to line up.
comet_666
Quote from: bill440rt on June 27, 2014, 02:48:57 PM
I know you are correct, I have 2 sets of these, one black and one green that was died black, this one is bent on the lower left corner pretty bad by the threads, only reason I used it was because I would have to clean the other with acetone to remove the dye and re dye it. I took the lazy way out.
Frames differ between AC & non-AC as well :Twocents:
VegasCharger
Quote from: Just 6T9 CHGR on June 28, 2014, 02:01:02 PM
Yes they are but doesn't a Non A/C dash frame have perforated lines on the backside to enable you to punch them out for the A/C vents  :shruggy:
six-tee-nine
where are the differences? Anyone have pictures of both to compare?
ACUDANUT
Quote from: comet_666 on June 27, 2014, 08:31:24 AM
Damn, find a donor/replacement dash. :Twocents:
bill440rt
Quote from: VegasCharger on July 05, 2014, 01:08:52 AM
No perforations.
Just measure 3 times, cut once.
Did a similar mod here:
http://www.dodgecharger.com/forum/index.php/topic,87688.0.html
