brake problem
Started by tucknroll, August 08, 2014, 07:23:17 PM
tucknroll
my 69 brakes have always been fine until today when it felt and sounded like the hose to the booster came off. i checked and it was connected but there was a small leak . i fixed the leak but it still feels the same and i hear a lot of air from somewhere around the brake pedal. could something be leaking where it goes through the firewall ?
Yup also the main diaphragm could have a leak.  :eek2:
tucknroll
is that the black rubber piece against the firewall on the inside?
tucknroll
also, would i fix it by taking the booster off or by taking the brake pedal stuff off?
Mopar Nut
Quote from: tucknroll on August 08, 2014, 09:31:10 PM
Both and removing the booster if bad from the car. You'll need to take the brake linkage and booster mounting nuts off from the inside the car.
"Dear God, my prayer for 2026 is a fat bank account and a thin body. Please don't mix these up like you did the last ten years."
This topic has pics of how to remove stuff: http://www.dodgecharger.com/forum/index.php/topic,70877.0.html
tucknroll
thanks. this forum has never let me down!
tucknroll
one more question, there is no leak from under the hood section and it is definitely got plenty of vacuum but inside when i push the brake pedal, i hear a loud hissing of air so shouldn't the booster definitely be bad?
I'd give Wayne a call. http://www.theramman.com/
(In my link you can see I gave up on boosters.)
tucknroll
got the new booster from yearone on and everything is good!
Mopar Nut
Quote from: tucknroll on August 13, 2014, 10:10:12 AM
Do you have YearOne's part number that you used?
