brights not working
Started by tucknroll, August 15, 2014, 08:41:40 PM
tucknroll
alright, i have a new problem. i just put on a new brake booster and had a tough time reaching the 4 bolts holding it on. i must have done something that affected the bright lights only. any thoughts?
dimmer switch, connection at firewall bulkhead connector, or all high beams are burned out
tucknroll
the bulbs are good and it is fine at the bulkhead. i pulled the carpet back and unpluged at the dimmer switch and put a test light on the 3 connections and only the top middle one had power. should they all
middle will have power all the time when headlights are on....one of the others will have power when low beams are on, and the other will have power when high beams are on....basically, 2 will have power all the time.
tucknroll
got a new switch and i have power at all three connections so do you know which one on the bulkhead connector is for brights
I don't have a 69 wiring diagram, so I cannot tell ya which wire it is
tucknroll
i followed it and found out i have power up to the lights so maybe it is the bulbs
well, that's what I posted in my reply above, but you said bulbs were good.....I just went on to other options after that
green69rt
Quote from: tucknroll on August 18, 2014, 06:24:20 PM
I have a hard time believing that all four burned out at the same time, but easy to check, just get an ohmmeter and check just one bulb.  There is a plug that is for the headlight harness.  I think it's in the area of the battery on top of the inner fender.  Maybe the plug has a bad pin??
tucknroll
sorry guys, you were right from the beginning. one bright bulb was shot and that made the other not work i guess because when the new one went in, they both worked!
green69rt
Quote from: tucknroll on August 19, 2014, 06:46:05 PM
That's a new one to me.  For those familiar with the electrical system, are these bulb elements in series??  Also, for dual headlights (assumption) aren't there four bulbs, two for bright only and two that are dual beam with high and low elements??  SO how would one bulb put them all out, I'm confused (nothing new.)
tucknroll
i dont know but the low beams never went out. both high beams were out but one bulb fixed both!
Stegs
Quote from: tucknroll on August 20, 2014, 11:21:37 AM
good to know, I tried my high beams and nothing worked, but my low beams work....so ill replace the bulb and maybe I will have the same luck
you wouldn't happen to know the part number for a high beam bulb would you?
tucknroll
h5001 is whats on the box.
not possible....one bad bulb will not cause all high beams to quit working....either you had a bad connection and you fixed it while checking, or you have a bad ground for the headlights.
The 2 outer bulbs have low & high beam, the 2 inner bulbs are high beam only....
tucknroll
i did some more checking and the new light seamed to fix the problem but then i wiggled the connection next to the battery and they blinked off again so it is a bad connection.
green69rt
Quote from: tucknroll on August 20, 2014, 07:30:38 PM
Ah ha!!  I had the same problem on an old charger.  The fumes from the battery corroded the connector.  I ended up replacing it.
Stegs
Quote from: green69rt on August 20, 2014, 09:57:33 PM
dumb question but are the connections for the passenger side headlights run from the drivers side? so if you have a bad connection on the drivers side, the passenger side wont work?
green69rt
Quote from: Stegs on August 21, 2014, 10:27:51 AM
IIRC the all of the lights are fed from one cable harness on the driver side.  "The only dumb question is one that is not asked."  -  my old high school shop teacher.
