Do I need ECU?
Started by comet_666, January 25, 2015, 08:44:27 PM
comet_666
Do I still need a ECU and a ballast resistor if I am running the below RTR distributor?
http://www.manciniracing.com/firretorundi.html
Nope. I jumpered my ballast threw the ECU in a box and never looked back. Soon I'm making a modified harness for the RTR.
comet_666
The REASON I got it....no more keeping just in case parts in the trunk. Full 12V coil, I tied start and run together at my column just to run (Blue) and that will soon become the "on" for a 40amp control relay, power fed off the 8ga. fleet upgrade parallel.  :2thumbs:
the ballast is for the coil...if you still are running stock Mopar coil, you need the ballast to cut the voltage down..otherwise it will overheat and short out
comet_666
I'm running this coil
http://www.manciniracing.com/fipecdr2rmic.html
and my RTR dist.
I was thinking of running this ECU instead of the Orange Box
http://www.manciniracing.com/reeligcoun1.html
Says 10-40 HP increase???? Is that right?
RTR (ready to run) dizzy fires coil. PAP (plug and play) dizzy use's ECU/ Ballast/ resistor as Mopar. I have THAT coil and RTR Dizzy.
