69 charger seatbelt bolts
Started by tiki, July 19, 2015, 11:18:23 AM
tiki
I am trying to locate the seatbelt bolts before I start the carpet any help is appreciated I did locate 2 male connectors that could go on the seat bolt?Before I put the dynamat down I located the rear seatbelt holes behind the back seat and put red tape around them just the front im wondering about :2thumbs:
tiki
found the 2 by each door now theres got to be another set by the tunnel?or do the male ends attach to the seat bolt?
tiki
I see a bolt hole for the shoulder belt are there 2 seat belts on one bolt next to the tunnel? :2thumbs:
Quote from: tiki on July 19, 2015, 02:08:42 PM
yes , one each side  , crawl underneath , you will see a reinforcement plate each side with a nut/ thread welded to it , that's where the seat belt bolt screws into ,  see green arrows below
 poke a screwdriver up from the underside to locate hole through the sound deadening , when you have fitted your carpet ,  poke the screwdriver up through the welded bolt again to locate hole in carpet ,  then from the top use a soldiering iron to enlarge hole to correct size
tiki
Thank-You for the pic, much appreciated!!!Now I have find some nice seat belts!!! :cheers:
bull
Best belts for the money right here: http://allmoparseatbelts.com/
The set I bought from him came with everything needed, including bolts.
Voss
Quote from: bull on August 09, 2015, 07:21:17 PM
Got all my belts for my 68 Charger from him, top quality. Bolts and everything included. P/n and date coded tags stitched in the right places. Really worth the money, he does a great job if you ask me.
green69rt
I have to say that all the seat belt bolts are not the same.  There are some that carry two seat belt loops.  Those have a longer "land" than those that just have one.  It's a little bit of a crap shoot.  I'll see if I can come up with some pictures of the different bolts tomorrow.  Pretty late tonight.
