Dash Frame Resto
Started by DC_1, August 04, 2015, 03:26:59 PM
DC_1
After posting my dash cluster in the electrical area I guess I should post the frame info here.
I blasted the frame. Epoxy coated, high build, sanded, re-primed and wet sanded with 600 before putting on a few coats of SEM trim paint. I shot it out of my HVLP gun using a 2.2 tip. It gave me a bit of a texture I hope duplicates the original look. Came out decent I think. Now I am starting to put it back together.
cdr
forsy1979
Did you restore the entire dash or who did you use?  Thanks!  I'm approaching this soon
DC_1
I also restored all the gauge faces and replaced all the dash buttons. I did it all myself. There is plenty of info on this site to help you along.
Dmichels
68 440 4 speed 4.10
Audiguy
Looks good. I especially like the wood frame you made to hold the damn thing. Great idea.
