Coat hooks screw hole
Started by bobfist, October 31, 2015, 04:36:13 PM
bobfist
Hi!
There is two screw holes there the coat hook goes, is it the upper or lower i shall use?
www.bobfist.com
Muscle Car Restorations & Reproduction
Sweden
cdr
this is where mine was, the other two that are up & down had a bracket for the seat belt snap.
bull
Don't take this as gospel but I believe there's supposed to be one coat hook and it's on the driver's side. Coats and shirts hanging over the passenger side rear window would have created a huge lane-change blind spot as well as being impossible to reach after the driver exited.
Also, if your headliner is already installed you can measure back from the outer driver's side visor screw 35.5" to find it.
cdr
Quote from: bull on November 26, 2015, 03:17:44 PM
you are correct Bull, but the picture is same left & right.
