Electrical Question
Started by gcdsn76, December 08, 2015, 01:53:34 PM
gcdsn76
What size female terminal goes to the spade terminals on the back of the fuse block? I was planning on splitting off the blower circuit. Also, has anyone had electrical problems with wiring an electric choke through the 12 volt side of the ballast resistor?
I'm pretty sure those are 1/4". The double blue wire on the ballast is the best source for choke power.
  I used control relays that tap into ALT. output (Black) to feed Both my Firecore RTR Dizzy and electric choke. They are turned on by the blue ignition wire. Both are fused 15amp between relay and device. This eliminated any voltage drop to the coil from the draw of the electric choke.
