Light Problems
Started by D69charger, January 28, 2016, 10:25:11 PM
D69charger
I want to know how to sort out the tail lights, brake lights and blinkers.  The wrong bulbs are lighting up.  The first pic is the tail lights (running lights).
D69charger
Brake lights
D69charger
Left Blinker
D69charger
Right Blinker
D69charger
the right blinker is lite up in the middle position of the tail light assembly.  I would like to make it light up properly
D69charger
Anyone have any ideas how to fix it??
Are the lamp sockets in the wrong spots?  You can pull them out and reinsert them in another slot.  Does that fix the problem?
If that doesn't do it then check all the bulbs and check for power on each pigtail to find a possible break in the wiring.
The wiring runs from the dash behind the driver side kickpanel and along the rocker.  Check the connectors for corrosion or other issues.  You can do a continuity test on the wires themselves so you don't have to tear out half the interior.  A multimeter and some electrical wire and alligator clips is all you need.
