Relay wiring
Started by 69dodge383, March 02, 2016, 11:02:38 AM
69dodge383
I bought a switch panel for my car off ebay.
It came with a relay and it is a 4 prong with 3 wires. I have not seen this before. It has 30&85 together on the relay.
This unit did not come with any instructions. So I am kind of not sure here.
I have googled this type of relay and checked summit and did not find anything.
Does anyone have insight on this?
Here is the link to the unit I bought
http://www.ebay.com/itm/381191586481?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The relay wires are numbered like so
Blue=87
Red=30
Black=86
Doug
The way I bought it
1969 Dodge Charger SE
383 Magnum
727
3.23 open 8 3/4 - 489
PS/MB
The way it is
1969 Dodge Charger "The Duke"
440HP '72
10.5:1 Mopar Pistons @.030 (446 c.i.)
Edelbrock Performer Heads
Hughes Solid Lifter Cam 278/283 245/250 .597. 613 108
7Qt Oil Pan
Victor Intake
Demon 850 Carb
TTI Headers 2" Primaries
727 Manual Valve Body
9" Dynamic Converter
4.10 Sure Grip 8 3/4 - 489
3" Dual Super 44
Coys 18x9 20x10.5  Cragar 15x8 15x10
cdr
with those two combined, you would have one power to  the relay, 86 would be ground, 87 should power up the board, 30,85 can be controlled by a switch. or hooked to battery & use the 86ground for the trigger.
69dodge383
Thanks for the help
-Doug
The way I bought it
383 Magnum
727
PS/MB
The way it is
440HP '72
7Qt Oil Pan
Victor Intake
Demon 850 Carb
3" Dual Super 44
cdr
you could also separate the 30 & 85,  battery on 30,, ign sw on 85
