Guess that part!
Started by comet_666, March 15, 2016, 06:50:44 PM
comet_666
Or tell me what wire this is behind the steering wheel please!!   :shruggy:
comet_666
Let me also ask could this be why my left turn signal does not work correctly?
PlainfieldCharger
That wire looks like it was the back of a switch. The eyelet is bent a little. It looks like the mushroom part that holds it on worked away...
You could start with the color of the wire and match it to the wiring diagram for a quick diagnosis. :Twocents:
igozumn
I think it goes under the turn signal switch mounting, err, I think it attaches to the bottom of the turn signal switch mounting plate and has a stud on the top side with a spring and ball that rides on the bottom of the steering wheel against the horn contact ring.  If your horn doesn't work, then that's probably the reason.  I have a spare column in the garage, but the switch is gone, so I'm not 100% sure.
A man walks into a psychiatrist's office wearing nothing but underpants made from saran wrap.  The psychiatrist says, "Well....I can clearly see your nuts...."
PlainfieldCharger
Quote from: comet_666 on March 15, 2016, 07:52:20 PM
Get a multimeter and check that wire for voltage when you switch on the turn signal :Twocents:
comet_666
Yah, horn does not work but I think there is nore than 1 reason for that. I will pull the wheel next week and take a closer look and test voltage to that wire for signal. I may be able to kill 2 birds with one stone fixing horn and signal!!
Thanks!
PlainfieldCharger
Quote from: comet_666 on March 17, 2016, 08:57:03 AM
Thanks!
Make sure you have the battery disconnected during disassembly. Does not appear to have a scorch mark on it but might want to check fuse too.... :scratchchin:
comet_666
