A/C Control Connection
Started by john108, May 11, 2016, 08:01:20 PM
john108
Hi
I am working on my dash wiring.
The picture shows the Dash Upside-Down on a table.
I disconnected things before I got to take some pictures, before removing the dash.
I am trying to decide which side of the speaker various electrical wires and vacuum hoses are routed.
Looking at the space behind there, I think I routed them the best I could, to clear the connections to the switch assembly.
The vacuum hoses are my biggest concern.
Which side of the speaker are they routed on your Dash?
I would like not to have things come up short or interfere later.
Any other comments?
Thank You
John
from memory  , as ive since changed mine now to the standard heater box set up  ,
 the fan & AC switch wiring runs down the right side of the radio  ,  the vacuum hoses down over the left side of the radio  , the water valve control cable  is just simply run as best as it can be with out kinking it , making smooth bends .
the main concern is , before putting glove box liner in , look up in side with a light , & operate the windshield wipers , just to make sure the arms do not rub anything , also as with any wiring under the dash watch out for any rubbing or chafing on the dash frame ,
john108
Hi tan top
Just so I understand Left from Right.  Flipping the picture confused me.
In MY picture, the Drivers side is on the left.
Are you suggesting that I move the AC Switch wiring over to the Passenger (Right) side of the Radio and speaker?
I will have to remember to put the wiper linkage back in the car before the dash assemble.  I have it in a box someplace.
Thank You
John
