turn signal switch 70
Started by charger01, May 22, 2016, 09:34:09 PM
charger01
how hard is this to change? the pigtail running down the column has me a bit nervous on how to change.. :shruggy:
70 sublime
I changed one on my green 70
After you get the steering wheel off and change the switch part it self
The plug on the end of the wires is very flat and wide but it will turn sideways (so it is parallel to the wires)  and just slide down the column
charger01
so the only thing you disassembled was the steering wheel and the switch itself?
