DodgeCharger.com Forum
June 25, 2019, 08:00:49 PM *
News: DodgeCharger.com decals are available here!
   Home   Help Calendar Login Register Chat
Pages: [1]   Go Down
  Print
Author Topic: Wing washers  (Read 1601 times)
70 sublime
Old Timer
Offline Offline
next project 1969 Charger 383 auto
« on: May 25, 2016, 08:19:02 PM »
Rounding up the parts to mount my wing
Question about the wing washers
I have seen lots of pictures where the rear 1/4 of Daytona's are cut to get the washers out
Are the metal washers only welded in along the trunk opening lip ?
Any of you clone builders that used glass washers did you fasten them any way or just with the bolts from the wing ?
Any pro or con on using metal ones or glass washers ?
Where to get metal reproduction washers or glass washers ?
Logged
current project 69 Charger Daytona clone F6 green
Nwcharger
Full Member
Offline Offline
« Reply #1 on: May 25, 2016, 08:28:04 PM »
Janek sells fiberglass ones, I had a set on my clone and didn't really like them. I have original ones for my Daytona and are tons better than the fiberglass repos. From what I can see it looks like the originals were just tacked to the trunk gutter.
Logged
1969 coronet wagon
Daytona R/T SE
Old Timer
Offline Offline
« Reply #2 on: May 25, 2016, 09:10:59 PM »
Just the studs/nuts from the wing.  Twocents
Logged
It started out as a rusty, green '69 R/T SE.
Now, it's well on it's way to being a Daytona.
A fake Daytona, that is.
Old Timer
Offline Offline
Old, Lost & Confuzed
« Reply #3 on: May 25, 2016, 09:15:54 PM »
no wing washers on my car...just the 3 nuts and flat washers under the quarter panel to the body and wing supports
Logged
Lighthorseman
Senior Member
Online Online
« Reply #4 on: May 26, 2016, 09:06:48 AM »
I seem to recall a thread in which someone used saran wrap and body filler to create a spacer that filled the void between the underside of the top of the quarter panel and the top of the fibreglass wing washer...
Logged
Hemi Runner
Senior Member
Offline Offline
« Reply #5 on: May 27, 2016, 04:43:30 PM »
I saw that too, might have been oldcarnut's thread. Here are my wing washers and support.
Logged
70 sublime
Old Timer
Offline Offline
« Reply #6 on: May 27, 2016, 07:26:44 PM »
Very nice
Is it bolted to the floor or just standing on it ?
Logged
Hemi Runner
Senior Member
Offline Offline
« Reply #7 on: May 27, 2016, 09:12:48 PM »
It's just setting on it for now. It will get fully welded around the perimeter of the baseplate.
Logged
Lighthorseman
Senior Member
Online Online
« Reply #8 on: May 29, 2016, 10:00:21 AM »
... Here are my wing washers and support.
Right click...save .  New wing washer install plan.  2thumbs 2thumbs 2thumbs
Thanks, Mr.
Hemirunner!
Logged
Hemi Runner
Senior Member
Offline Offline
« Reply #9 on: May 29, 2016, 02:32:05 PM »
Anytime. If you need more ideas, my build thread is on forbbodiesonly.com under the same name.
Logged
oldcarnut
Old Timer
Offline Offline
« Reply #10 on: May 30, 2016, 12:00:28 PM »
That was me but it was foil not wrap.  I'll post a pic off my phone when i resize it
More on page 2 Worked good for me
http://www.dodgecharger.com/forum/index.php/topic,53678.25.html
Logged
70 sublime
Old Timer
Offline Offline
« Reply #11 on: May 30, 2016, 01:36:26 PM »
Is there another piece of channel on the bottom side of the wingwasher that the wing bolts down through and the braces also bolt to ?
Logged
oldcarnut
Old Timer
Offline Offline
« Reply #12 on: May 30, 2016, 01:58:49 PM »
Here's a pic of the Janek washer I had. Top and bottom side just fiberglass.  The bolts run through it and a hole in the metal flange of the supports.  Nothing metal running across the whole underside.
Logged
rainbow4jd
Full Member
Offline Offline
« Reply #13 on: February 21, 2019, 07:43:46 PM »
Interesting.   Is the Superbird the same washers?     If you were redoing a Daytona you might be able to use the Superbird ones.   Just a thought.
Logged
DAY CLONA
Old Timer
Offline Offline
« Reply #14 on: February 21, 2019, 09:36:25 PM »
2 different "washers", size, shape, curvature, wing bolt pattern, etc, etc
Logged
still winging it at www.officialdayclona.com
rainbow4jd
Full Member
Offline Offline
« Reply #15 on: February 21, 2019, 09:58:43 PM »
Makes sense.    I was thinking if they were just tack welded in, there might not be a difference in the actual washer itself.
I've been thinking myself about doing a clone (because I'm too scared to drive my original bird anymore).    So, these little things are starting to float around in my mind.
I guess I would need to take a close look at my bird to see exactly what they look like.   I wonder if they were a common manufacturing washer used in other applications at Chrysler.
I hate when my brain starts asking these crazy questions.   Now, I'll be obsessed until I find an answer!  ugh!
By the way - I've been a long time admirer of your build.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.059 seconds with 17 queries.
