headliner question
Started by tucknroll, June 15, 2016, 06:26:16 PM
tucknroll
I'm about to attempt to put a new headliner in my 69. Just wondering how to remove the two small bows by the sail panel. Thanks
70 sublime
Just use a flat screw driver and pop them out by prying close to the end where they go into the roof pannel
tucknroll
lexxman
Hey I was wondering do have the glass in the car? I'm going to be putting headliner and front and rear glass in. Not sure witch to do first.
70 sublime
Do the head liner first then the glass makes it easier
tucknroll
Glass is in. I know it'll be a nightmare but I'm gonna give it a shot
cdr
tucknroll
I got the headliner up by the bows and hooked a few of the teeth. im wondering if the glue is really a must. seems like after all the teeth are hooked and the trim is on, it would be pretty snug. what do yall think?
cdr
did you watch the links I posted ? I had to use glue on the edges .
lexxman
I'll have to watch those before doing mine. I'll need all the help I can get. :lol:
tucknroll
I did and they were very helpful. I'm just not sure ill need glue all the way around. Its looking pretty good without it so far
lexxman
Isn't there clips on the sides to hold it in place? Those videos will help, I think another pair of hands will be good too.
bill440rt
My headliner install thread:
http://www.dodgecharger.com/forum/index.php/topic,31212.0.html
Yes, you need glue. Helps to hold it in place.
You'll especially need it around the rear window, sail panels, and the top edge of the windshield area.
tucknroll
I finished it. It was a huge pain but I did pretty decent. The back windows were a nightmare!
HeavyFuel
Yeah...headliners suck.   Probably the only thing worse is the quarter windows.
