DodgeCharger.com Forum
January 20, 2022, 01:17:56 AM *
News: Please remember: this is the place to discuss Chargers - NOT the place to discuss politics. Political posts will be locked or deleted at the Moderator's discretion.
   Home   Help Calendar Login Register Chat
Pages: [1] 2  All   Go Down
  Print
Author Topic: 512 Stroker Dyno time  (Read 9526 times)
comet_666
Old Timer
Offline Offline
« on: June 16, 2016, 06:34:08 PM »
Put the 512 on the dyno today!!
I think it's 10.75:1 compression. Still getting final details.
4 pulls, still waiting on the print out which I will post along with video
580 HP @ 5400 RPM
660 TQ @ 3900 RPM
Logged
Old Timer
Offline Offline
AKA... "The Game Changer"
« Reply #1 on: June 16, 2016, 06:52:48 PM »
Sweet!  Gobs of torque down low cheers
Logged
Back N Black
Old Timer
Offline Offline
« Reply #2 on: June 16, 2016, 07:40:46 PM »
Nice!!! do you have the spec of your build?
Logged
comet_666
Old Timer
Offline Offline
« Reply #3 on: June 16, 2016, 08:33:08 PM »
Video
https://www.youtube.com/watch?v=K42AgSQZGwg  - Pull 3
https://youtu.be/zzUd914sV5U - Pull 4
Build:
Eagle Comp rotating assembly 21203
https://www.cnc-motorsports.com/eagle-21203-bb-chrysler-440-520-stroker-competition-rotating-assembly-kit-11-3-1-mahle-flat-top-pistons.html
Edelbrock rpm Heads
Performance cam brgs
Edelbrock Intake rpm 7193
ARP Main Cap Studs 140-5402
ARP Head Bolts 145-3706
Brass soft Plugs
Felpro Head gasket 1009
Felpro intake Valley Peformance
Cam Button and Plate
Howards Hyd Roller Cam 723445-10
Comp Pro Magnum Lifter Hyd.Roller 8921-16
ARP SS Intake Bolts
COMP Cams Pro Magnum Shaft Mount Roller Rocker Arms 1621-16
Timing Chain set Roller thrust brg.
Oil pump 63HP Melling Select
Oil Pump Drive Brass gear for roller gear p3690875
Manley5/16 x.08 Pushrods
High Flow Water Pump Milodon 16360
Stock Housing
Edelbrock Performer RPM Street Fuel Pumps 1723
Polished Valve Covers SUM440350
Carb  Quick Fuel HR850
Stroker Windage Tray
Alternator   8509DSP
Firecore RTR Dist   CWSFC-1007B
FireCore Performance CD R2R Mini Coil CWSFC-CDM
Converter   729330ATI
3.23 gears   YG C8.42-323
OBX Headers Primary Tube  1.8 " OD
Wizard 26" radiator 1640-100  / 1.25" tubes
Logged
PlainfieldCharger
Senior Member
Offline Offline
« Reply #4 on: June 17, 2016, 07:08:46 AM »
That sounds pretty mean!! 2thumbs That will be fun to drive......... icon_smile_cool
Logged
myk
Old Timer
Offline Offline
« Reply #5 on: June 17, 2016, 07:49:49 AM »
Good times for sure!
Logged
Global Moderator
Old Timer
Offline Offline
572 street/strip bullet
« Reply #6 on: June 17, 2016, 08:00:54 AM »
Very nicely done !  2thumbs
That'll be a handful on the street   icon_smile_big
Logged
Chargerguy74
Old Timer
Offline Offline
« Reply #7 on: June 17, 2016, 11:46:41 AM »
Nice!
Logged
WANTED: NOS or excellent condition 72-74 4 speed shifter boot for bench or centre armrest car, part number 3467755. It's a rubber boot that looks like it's sewn up leather.
WANTED: My original 440 blocks. Serial # 2A188182 and 3A100002
comet_666
Old Timer
Offline Offline
« Reply #8 on: June 19, 2016, 10:14:54 AM »
I have not driven this car in almost 10 years and it was nothing like it is now. I am a bit concerned about my lead foot and my girlfriend is actually a bit scared to ride in it.  popcrn
Logged
XH29N0G
Old Timer
Offline Offline
no matter where you go, there you are
« Reply #9 on: June 19, 2016, 10:40:45 AM »
Well then, take your time to get used to it, and enjoy.
Logged
Or maybe it protects us.
68CoronetRT
Senior Member
Offline Offline
« Reply #10 on: August 09, 2016, 07:56:37 PM »
What headers are those?
Logged
comet_666
Old Timer
Offline Offline
« Reply #11 on: August 09, 2016, 08:22:18 PM »
OBX
Logged
500Jon
Senior Member
Offline Offline
« Reply #12 on: September 06, 2016, 12:01:50 PM »
All that lovely power with a Vac Sec and a mech fuel pump!
ENJOY!!! drool5 drool5 drool5
Logged
IF A JOB's WORTH DOING, ITS WORTH DOING WELL, RIP DAD.
4-SPEED, 1969 Charger-500 is the most Coolio car in the World!
chapel40
Junior Member
Offline Offline
1971 383 Factory Air
« Reply #13 on: July 20, 2017, 10:40:25 AM »
Which block is this? 400 or 440?
Logged
Don Chapel
BLK 68 R/T
Old Timer
Offline Offline
68 Charger R/T, 493 stroker engine, 727 auto.
« Reply #14 on: July 20, 2017, 10:57:53 AM »
It's a RB (440) block. You can see the machined pad on the front left side of the block.
Logged
Tmb84
Junior Member
Offline Offline
« Reply #15 on: August 05, 2017, 06:58:38 AM »
looks nice
Logged
70' Charger 383 -top banana
71’ hemicuda Sox&Martin ”tribute”
comet_666
Old Timer
Offline Offline
« Reply #16 on: February 06, 2018, 08:24:51 PM »
Thanks!!
Logged
chapel40
Junior Member
Offline Offline
« Reply #17 on: February 07, 2018, 02:25:38 AM »
Thanks for taking the time to put your engine on here, I have used some of the information for the one I'm building. 2thumbs
Logged
Don Chapel
chapel40
Junior Member
Offline Offline
« Reply #18 on: February 19, 2019, 02:08:21 AM »
What is the stall speed of your torque converter?
Logged
Don Chapel
comet_666
Old Timer
Offline Offline
« Reply #19 on: February 19, 2019, 03:57:40 PM »
I believe 3000-3500
Logged
chapel40
Junior Member
Offline Offline
« Reply #20 on: February 24, 2019, 01:42:36 AM »
Did you get it installed in the car? How do you like it and how does it perform?
Logged
Don Chapel
alfaitalia
Old Timer
Offline Offline
« Reply #21 on: February 24, 2019, 05:18:15 AM »
Completely unsilenced big bore motor, dynoed outside (effectively!)  noise and fumes just venting to the outside world. That shop must be real popular with the neighbours!! Never seen a dyno over hear that wasn't in a sound deadened room with exhaust extraction and filtration and safety guards in case of catastrophic rod or flywheel failure and the operators behind the glass! You Americans and your fun attitude to heath and safety! Long may it continue...LOL!
Logged
comet_666
Old Timer
Offline Offline
« Reply #22 on: February 28, 2019, 07:08:30 PM »
Yes, I have around 3500 miles on it as of now, drives great! With 3:23 rear gears I can cruise at 70 all day and light them up at will.
Logged
comet_666
Old Timer
Offline Offline
« Reply #23 on: February 28, 2019, 07:10:39 PM »
you know..I have watched tons of shows about engines and have seen many on dynos and at no time did it ever occour to me, until you mentioned it, that mine took place exactly as you described lol
Logged
375instroke
Old Timer
Offline Offline
'69 Charger R/T black, '69 Charger 383 Cordovan
« Reply #24 on: March 13, 2019, 06:31:19 PM »
I've only owned stock Mopars.  I'm not used to driving 500HP cars.  I see people commenting on stroker builds with comments like "Dual plane, 850CFM, tiny 1-3/4" headers? Jesus, put a cork in it, why don't you." "You need at least 250°@.050", or it'll fall on it's face."  "You need solid cams if you want to make power."
You got a dual plane, 850cfm carb, 1.8" headers, and 235° @.050" hyd. roller cam.  Are the RPM heads the smaller Edelbrock heads?  I see so much hate on "tiny" specs like this, on other posts, and you're making 580 HP @ 5400 RPM and 660 TQ @ 3900 RPM!  Those look like outstanding numbers to me.  How can this not be a blast to drive?
Logged
Pages: [1] 2  All   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.065 seconds with 18 queries.
