Dash bulbs
Started by M5Ivan, December 02, 2016, 07:53:35 PM
M5Ivan
I bought these LED's from SuperBrightLED's to replace my dash bulbs per a post on this forum. Looking at the bulbs, I'm not sure they're the right ones? I pulled one dash bulb out, but the glass came out, not the base. That will be fun to try and remove from behind the dash...
Any idea if these are the right LED's?
M5Ivan
Figured it out, wrong bulbs. Bummer.
68 charger freak
They look like they should fit into the dash ,they fit into black bases that screw into the circuit board, There isn't any wires that are directly connected to the lights because they draw power from the board
68 charger, pro touring build ,mini tub,528 wedge,magnum-xl 6 speed,rms alterkation,martz 4 link,moser 8.75,custom interior
cavemanno1
Someone could post up a link for the led bulbs for this because i'll need them as well.
draftingmonkey
On SuperBrightLED's did you use the vehicle search for your bulb selection https://www.superbrightleds.com/vehicle?reset=1? I would think you used a BA9 base bulb (pictured below) vs the Mini Wedge base bulb you show.
M5Ivan
Just realized these bulbs replace the ones on the right hand side of the instrument panel. The new bulbs I just bought are for the left hand side of the panel. So you need both kinds to replace all of the bulbs.
PlainfieldCharger
Will the led's work with the dimmer? :shruggy:
M5Ivan
I've read they do, but my cluster is currently sitting in my kitchen so I'm unable to test it at the moment. Debating whether to send the cluster out for restoration......
cavemanno1
How about the exterior led bulbs for the turn signal?Do they have to be Amber or white?
There is an old thread here where White and Red used super white Led bulbs for the front turn signals but don't they have to be amber?
http://www.dodgecharger.com/forum/index.php?topic=74412.0
In his post,he was using these for turn signal https://www.ledlight.com/s25-24-led-light.aspx
These are a lot cheaper than these ones https://www.superbrightleds.com/vehicle/1968-dodge-charger-vehicle-led-lights?make=22&model=536&year=1968
Why are these a lot more expensive,like14 bucks just for one bulb vs $7?Is it worth going with the more expensive one?
