First start up
Started by 1charger69, December 28, 2016, 01:30:02 PM
1charger69
Is there anything i need to do underhood to start my car for test....there is no interior yet or dash wiring bulkhead connections.    All underhood wiring including the orange box ecu and electric choke is hooked up....just not plugged in to the bulkhead.
BLK 68 R/T
You pretty much need to have the dash wiring harness installed to start the car, and at least the engine harness connected to the bulkhead in order to start the car. Without it you will need to do quite a bit of bypass wiring and misc connections in order to get it to start  :Twocents:
Edit: you might be able to get away with running a hot wire directly to the ballast resistor from the battery, then jump the starter relay to turn the motor over. I guess this would depend on if everything is stock or not?
