Whose front end kit?
Started by Wakko, August 10, 2005, 10:47:58 PM
Wakko
I want to rebuild my steering on my '69.  What kits have you used that are reasonably priced?
Ian
'69 Basketcase, bluetooth powered
Boynton 236 F&AM
I use Energy suspension for the bushings & Moog Ball joints & tierods etc
694spdRT
I bought mine from Performance Suspension Components. The kit had some Moog parts in it. It was the best price for a complete kit that I found.
www.performancesuspension.com
1968 Charger 383 auto
1969 Charger R/T 440 4 speed
1970 Charger 500 440 auto
1972 Challenger 318
1978 Ramcharger 360 auto
CFMopar
QuoteI use Energy suspension for the bushings & Moog Ball joints & tierods etc
:iagree:
1971 Charger SE 440 automatic
2014 Ram EcoDiesel Laramie
I used a combination of parts as well.  Energy Suspension for the urethane parts, Moog for the hard parts and there is some TRW in there too.
flashley18
I have heard that the Graphite urethane bushings still squeak.  Anyone having any trouble with squeaks?
I want to help the handling on the 71 all I can but I don't want anoying squeaks.
I went with rubber for anything that rotated (like control arm bushings) and urethane for anything that took a compresion load (like sway bar or strut rods). and mine does not squeak.
Charger4404spd
I did a little looking on the net for Moog parts. Heres the part numbers I have for a 69. I would say they are the same for 68 and 70 models as well. I will be going to the local parts store here next week for prices.
K408  Upper CA bushing kit
K791 Lower  "                     "   (2 required)
K772 Upper Ball Joint             (2 required)
K781 Lower Ball Joint Leftside
K783 Lower Ball Joint Rightside
K5110 Swaybar link kit           (2 required)
K7016A Strutrod Bushing Kit
68ChargerJMP
Anyone have problems getting those damn poly torsion bar boots to fit??? Whats up with those?
Not NEARLY as many problems as I had getting the sway bar bushings on.  The stuff is tight but it does go on eventually.
694spdRT
Quote from: 68ChargerJMP on September 18, 2005, 11:12:19 AM
Yes...got digusted after trying to get them on for about an hour and went back to rubber. They don't look "stock" anyway which is what I wanted in the first place.
1972 Challenger 318
