tech Decal location
Started by 41husk, February 06, 2017, 02:33:21 PM
41husk
I have some decals that came in a Phoenix graphics kit.  I called Phoenix graphics and they apparently don't know where there decals go.
1. Jacking instructions for sure grip Differential.   It is a white with red print decal.  I have read that they are only on 62-67 cars.  I have heard that they went on the inside of the glove box door, and on the inside of the deck lid near the jack.
2 Vehicle manufactured following all United states safety standards  This is a black decal.
3. Warning disconnect regulator before servicing  This is a small red tab looks like it is held down with a screw.  It is not adhesive.
4. Tire pressure  I know this goes on the driver side door jamb, but not sure exactly were.
Any pictures or info would be greatly appreciated.   Thanks!
1970 Plymouth Duster FM3
1974 Dodge Dart /6/904
birdsandbees
Here's the standards sticker spot.... see the sticker under my '89 paint job  :brickwall: .. above the jam switch location
Faces to read from the drivers seat.
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
birdsandbees
Air Pressure on my '70 Bird... imagine the '69 went in the same place, but hopefully someone can confirm.
 :yesnod:
these are from a 69 charger
jack instructions are what I have found on unrestored original chargers , not saying there are no variations  never say never etc
A location   1968 & 1969  Hamtramck cars
B  location   1968 & 1969 & 1970  St Louis  cars
C  location  1970 St Louis cars
  the sure grip decal , have seen them inside the trunk lid  ,  not sure if it was the original location  , also see / heard in the glove box  stuck to the side or on the fuse box door ,  also stuck to the owners manual /warranty booklet  plastic wallet  :shruggy:  ....... :popcrn:
think from memory the red triangularish   red alternator label is actually attached by the green field wire male spade connector  , sort of clamped between it , so when the field wire is connected you cant see it  , or just the edges  :scratchchin: , I await to be corrected on any of these  :yesnod: :2thumbs: :cheers:
41husk
Thanks guys.  That will do it!! :cheers: :cheers: :cheers:
