LO23 hemi dart
Started by Q5XX29, March 07, 2017, 07:02:12 PM
Q5XX29
Thanks guys, appreciate your input, and agree. Nacho, I'm not sure- I was just going off of what my builder told me and I'm embarrassed to admit I don't even know, myself... but I will sure check into that. Yes, correct in that the LO23s started life as 383 cars,  but not sure if anything was changed at Hurst
dakota_gt on Instagram
BDF
Quote from: Q5XX29 on July 19, 2017, 08:55:27 PM
Um, I didn't post any more photos, just text...
All the previous pictures you posted are photo-bucketed-up (gone). We would like some more please!
:cheers:
Quote from: Q5XX29 on July 20, 2017, 07:03:16 PM
Well clicking on the Bendix rotor INFO box ( Centric doesn't show these specs )
Style   Full Cast
Type   Disc Only
Design   Vented
Studs   5
Supplied Stud (in)   No
Outside Diameter (in)   11.04
Nom Thk (in)   0.81
Min Thk (in)   0.79
Bolt Circle (in)   4
Overall Height (in)   2.275
Alternate/OEM Part Number(s): 3580502
BENDIX Warranty Information
The only info we got don't get here is the inner and outer bearings diameters ( outer diameter is the deal since pretty sure spindles are the same hence inner diameters should be the same with GTSs spindles )
If they are the same, Centric drilled and slotted rotors are a good upgrade on stock specs car allong with ceramic pads! BTDT!
