turning a 70 into a 69
Started by 200MPH, March 15, 2017, 06:34:13 PM
200MPH
I was wondering how hard is it to swap in the 69 steering column into a 1970 along with the 69 style  key in the dash  no I'm not building a General Lee :2thumbs:
Charger
Charger-Bodie
As long as you have a 69 dash and steering column it's just a matter of switching the parts .
wiring harness will be different as well....along with the turn signal switch connector
200MPH
Quote from: Charger-Bodie on March 15, 2017, 06:45:02 PM
so the dash is not connected  to the vin number  I could just swap them out ?
Charger
cdr
get the proper rivets from ECS & install the correct VIN that belongs to the body on the new dash frame.
Kern Dog
Will you be selling the fenders/grille/hood, etc?
200MPH
Charger
Kern Dog
ACUDANUT
My 70 Charger has a COMPLETE 68 interior. Dash and all. :popcrn:
200MPH
Charger
200MPH
I guess I should explain one more, I'm making the inside of my 70 to like a 69. I want to move the key to the dash and I want 69 vinyl dash pads in place of the 70's  plastic..
Charger
Kern Dog
You could certainly shop around for a bare 68-69 dash frame for any B body AND then just cut and section out the ignition lock cylinder portion.
200MPH
 Does the Plastic /vinyl dash upper and lower parts swap out ?
Charger
70 sublime
68 dash pads come to a point over the heater controls
69 and 70 are the same and are just straight across above heater controls
200MPH
I was just wondering if the 2 pieces vinyl in plastic mounted up the same.. on the 70 - did just cover up the keyhole?
Charger
70 sublime
Quote from: 200MPH on March 21, 2017, 12:06:21 PM
Yes i think they will fit both cars the same way
Not sure if the key hole is cut into the 70 metal dash frame though
Glove box door is different for 70 vs 69
70 opens down and 69 opens up
ACUDANUT
68 and 69 Chargers are more prone to auto thefts with the ignition not in the steering column.  :Twocents:
the 4 way flasher switch is in the dash on a 69, it's in the column on a 70.....so the entire dash wiring harness will need to be swapped out as well......along with the instrument cluster bezel
Charger-Bodie
Quote from: ACUDANUT on March 22, 2017, 02:05:06 PM
There's also the fact that more people want to steel a 68-69 than a 70 too
ACUDANUT
crj1968
Car thieves are now selective on 2nd gens?     :scratchchin:
Charger-Bodie
Quote from: crj1968 on March 22, 2017, 05:29:15 PM
I was only joking.
crj1968
Kern Dog
That is also why he wrote STEEL instead of STEAL.
