68 Rear Defog switch
Started by Hemidog, March 19, 2017, 03:58:39 PM
Hemidog
On a 68, can I use a 2 speed wiper switch for the rear defog, or are they unique?
It looks similar on the pictures I have seen...
Hemidog
Dans 68
Being that the rear defroster switch was a simple on and off switch, it should work if the 2-speed wiper switch is a physical match to the dash rear defroster switch opening. Have you tried a test fit yet?
Dan
BLK 68 R/T
Sitting here thinking the emergency flasher switch might work better. Isn't it just a 2 prong switch  :shruggy:
Charger-Bodie
Rear defog switch is two speed. I have a functioning set up in my 68
Dans 68
Quote from: Charger-Bodie on March 28, 2017, 08:09:08 PM
Right you are! I went to my '68 to confirm. By the looks of it a 2-speed wiper or headlight switch are the same, and would work.
Dan
Charger-Bodie
It has 3 spades on the back
Hemidog
Well, I decided to check it myself. You can indeed use a 2-speed wiper switch to work the rear defog fan :)
The switch has 6 spades, but you can use 3 of them (P-12v, A-Low, F1-Hi).
Now for the bad news, the switch itself does not fit the rear defog hole on the instrument cluster :( The "bolt-pattern" is different, it has 2 holes on 1 side, like the hazard switch).
Does anyone know if the rear defog switch was used on other applications/ other functions, or is it unique, and therefore almost impossible to find?
Hemidog
The one you've linked to could be easier to modify, but it would cost as much as some other auctions with the correct switch, where the bracket is only on 1 side with 2 holes.
