Rallye dash harness
Started by Mopar Crazy, March 27, 2017, 09:43:25 PM
Mopar Crazy
I'm looking for a new and complete plug in dash cluster wire harness for my 68 Charger, rallye cluster with a/c.
I would like to find a plug n play harness rather then splicing any wires if possible.
There are a few companies out there but not sure whats good or not.
Any help would be appreciated.   :2thumbs:
Do it Once and Do it Right !!!
BLK 68 R/T
Pretty much your only option for a stock plug and play harness is M&H. They are exclusive to year one, so wait until you have a discount code to order. Or are you looking for a not stock harness?
Mopar Crazy
M&H ?    I'm not to concerned about stock or correct harness. As long as it's going to have the correct plugs for the gauges, lights, cluster lights,  ect.
Thanks for the reply
birdsandbees
I just bought engine, headlight and tail light harnesses through Year One to get the M & H plug and play.. with a 25% off code!  :2thumbs:. They look very correct compared to my old ones. Imagine the dash harness would be of similar fit form function.
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
BLK 68 R/T
I have installed 2 dash harnesses from Year One. One in my old 68 GTX and one in my current 68 Charger. Both fit perfect with no issues. They have all the correct plugs to install to factory gauges. Be aware that they are the base harness only, meaning A/C harness wiring, map light, ignition light, glove box, console, ash tray light and any other wiring considered an "accessory" is not part of the harness. You will have to fabricate//buy new if available/purchase used any of the other harnesses as needed.
Edit: here is a link to get you started
https://www.yearone.com/Catalog/chrysler.b.body/electrical/harnesses
Mopar Crazy
Any one have any experience with Classic Ind. Harness ???       MB-2443  $469.99 w/ 20% off
( MB2443 - 1968 Mopar B-Body Under-Dash Wire Harness - With Oil Gauge
Replacement under-dash harness for 1968 B-body models. Our harnesses feature correct color wires, factory style connectors and is wrapped in non-adhesive vinyl wrap tape. Under-dash harnesses connect to various switches and sensors related to the dash, the harness also attaches to the engine harness and runs down the side cowl panel in order to connect to the rear body harness. )
Important: When ordering a new wiring harness inspect the original harness on your vehicle.Chrysler often added separate wire
BLK 68 R/T
I believe they are M&H harnesses. I think Classic Industries gets them from Year One. They are listed as discount exempt on Classic Industries website.
Mopar Crazy
Great info... Thanks BLK 68 :cheers:
Mopar Nut
Quote from: BLK 68 R/T on March 28, 2017, 02:17:10 PM
:iagree:
Wait for a 30% off sale from Yearone, should be one coming up.
Mopar Crazy
birdsandbees
TIME TO ORDER!!!
30% off.. code FINAL
Mopar Crazy
Awesome !  Thanks for the heads-up....  :cheers:
