Roof Skin Replacement
Started by rikubot, April 29, 2017, 10:00:20 PM
rikubot
About the question about the picture: the flange is not as dramatic as the picture makes it look. If I remember correctly, the skin sits just about even with the quarter when it's sitting on top of it. I will get a pic of it with a straight edge on it next time. But in the picture it definitely looks pretty pronounced.
'69 Charger, 440/727
Dreamcar
Quote from: rikubot on May 28, 2017, 07:26:43 PM
THIS! yes, use a straight edge, and if its just about right, then leave the roof on top of the quarter, plug weld it first, then fill it. If you have to take the roof off 20 times, if does matter as long as you get the last test fit right before welding.
"And another thing, when I gun the motor, I want people to think the world is coming to an end." - Homer Simpson
1969 Charger, 383, Q5/V1W, A35, H51, N88,  numbers match (under restoration)
Dreamcar
"because it seems the stamping didn't crease the lip enough".
We would need to see this, or at least I do. I don't get it.
rikubot
Quote from: Dreamcar on May 28, 2017, 07:30:44 PM
Okay, I will try my best to get a picture illustrating what I mean. I'm trying to think of a way to draw it that might explain what I mean.
Update: there is no way in hell I could draw what I'm trying to describe. It would be even more confusing to the situation. Failed miserably lol
rikubot
Sorry in advance. Hopefully this will make sense.
Dreamcar
Quote from: rikubot on May 28, 2017, 08:20:36 PM
You just need to bend and clamp it for welding.
rikubot
Some more pics:
o
You can see a little better how the flange is a bit more subtle than the other pics made it look.
rikubot
Heres where I meant the skin comes up short from the drip rail for about 3-4 inches.
Dreamcar
the seam looks fine now with the level sitting on it. How is it fitting everywhere else around the car? Is it hanging up anywhere that could affect how it fits in that corner? What about around the windows?
You could maybe make a relief cut and pull in down towards the drip rail and weld it back up after (see green line representing the cut and arrow)?  Making small relief cuts like this is not uncommon with new panels.
rikubot
Everything else looks pretty good. I measured the two c-pillars along the seam and the driver's side came up about a quarter inch shorter than the other. Kind of a strange mistake for AMD to make but it seems like that's the only possible explanation for that seam coming up short. I think that relief cut is the only way around that issue. The drip rail seams I think will fit better in the drip channel once I bend them a little more. It's definitely not hanging up anywhere. The top of the c-pillar looks pretty flush after the trimming. The trimming helped quite a bit but I am going to measure that distance on each side again to make sure it's the skin that's uneven, then probably put that cut in it right where you have it drawn.
mopar4don
Just a suggestion:
If you do a relief cut, slice it as close as you can to the bend.
The farther out you in a flat panel the better the chance you will get oil canning or distortion.
rikubot
Quote from: mopar4don on May 31, 2017, 02:40:19 PM
Just a suggestion:
Thanks for the advice. The longer the cut, the less the bend, right? I am a little afraid the warp the metal welding in a little piece there...pretty much just a sliver.
rikubot
What do you all think of using panel bond to attach the roof skin?
charger_fan_4ever
Quote from: rikubot on May 31, 2017, 11:35:40 PM
we only welded mine at the front and rear window channels,a pillars,at the 1/4 seam.
Used the bond all along the drip rails and cross pieces.
