flasher location
Started by Moeggenpar, May 01, 2017, 07:47:13 PM
Moeggenpar
I'm putting in new LED tail lights and replacing the flasher on my 68' Charger. Where is flasher located?  Thanks
BLK 68 R/T
Should be on the side of the ashtray.
Edit: both of them, 4 way hazard and turn signal flasher are on each side of the ash tray.
Bronzedodge
Is that the same for '69?  Or did they get moved?
Mopar forever!
Charger-Bodie
Quote from: Bronzedodge on May 02, 2017, 04:39:48 AM
There should be one on each side of the steering column on a 69. If I'm remembering correctly the one to the right is hazzards.
pic of behind dash of a '68  Flashers on either side of ashtray.  IIRC in '69 they were installed in metal spring clip retainers attached to the metal dash frame behind the lower pads on either side of the ashtray....these seem to be loose in the pics...
Charger-Bodie
The 69 chargers I've worked on were to each side of the column. 68 by ashtray
Moeggenpar
Quote from: Just 6T9 CHGR on May 03, 2017, 07:57:07 AM
Thanks a lot for the pics!
68 RT
My 68s are next to ashtray.
