71 Superbee Radio
Started by Simonic, May 07, 2017, 04:44:50 AM
Simonic
Mopar owner in the UK..
ACUDANUT
 I Get my Music from my engine these days !!!
ODZKing
 ::) Looks as if you would have to cut the dash bezel to make that work  :o
Simonic
Quote from: ODZKing on May 07, 2017, 09:37:14 AM
Cut the dash?
This is the listed radio for the 71,it looks the same size and shape as the one ive removed and my dash isn't cut....
ODZKing
The radio face has rounded corners, that radio you showed is square. Unless it doesn't actually sit flush in the hole
Bere is how it sems to fit on cluster bezel... its standard cluster but opening is the same
Seem to fit just right behing the opening and not INTO the opening
Simonic
Quote from: Nacho-RT74 on May 07, 2017, 05:36:19 PM
Thank You Sir.
Is this fitted in your car?
Does it work ok for you?
Any issues?
71charger_fan
I bought a Retrosound and it was the same deal. Just a little too tall to fit through the hole in the cluster. It's expensive, but I was considering paying up for one from these guys that does fit the dash opening. http://www.radiosforoldcars.com/
Simonic
Thank You gentlemen.
I'm going to give one of these radios a go.
