New Fender Tag
Started by Mopar Crazy, May 09, 2017, 11:45:21 AM
Mopar Crazy
My fender tag is missing from my 68 RT.  Does anyone around stamp new tags ?
Do it Once and Do it Right !!!
70 sublime
Do you have the build sheet to know what should be on the tag ?
Mopar Crazy
69CoronetRT
Quote from: Mopar Crazy on May 09, 2017, 11:45:21 AM
Yes, but if you want an accurate tag, you will need to supply the info. Do NOT rely on a tag maker to know what is correct. Chances are good you will spend a lot of money on a bad part.
Mopar Crazy
Good advice, thank you  :2thumbs:
B5 Charger
birdsandbees
Quote from: B5 Charger on May 12, 2017, 03:51:45 PM
MMC does Mopar tags.
http://www.mmcdetroit.com/Datatags/
Yep. and David will work with you until you both agree everything is correct.
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
