Started by xx29440charger, June 19, 2017, 09:53:37 PM
xx29440charger
Anybody running 255 60 15 inch on your 68 69 or 70 Charger? Any rub in the front? Let's see some pics!
RallyeMike
... and the answer will need to include the wheel width and backspacing to have any meaning...
1969 Charger 500 #232008
1972 Charger, Grand Sport #41
1973 Charger "T/A"
xx29440charger
255/60/15 on all 4 corners with no rubbing.
15x7 Road Wheels
15x7 Steel
xx29440charger
Thank you for posting!!
RiverRaider
I have G60-15 bias Indy's which run about the same or slightly wider than 255/60/15 on a 8" wheel 3.75" or 4" back space (I forget which sorry)
No problems with clearance
The new tire next to it is a 295/50/15.
My first Charger was a Stock Car.
RoscoePColtrain
235 60 15 BF Goodrich Radial TA's on the front and 275 60 15's on the rear, mounted on 15" x 8" x 4-1/2" Bolt Circle, 4" Back Spacing OEM Type Stamped Steel Wheels.
moparstuart
exact same tire size i run
255/60-15 is to me the best suit tire on B bodies all around
Just ordered 4 Torq Thrust D 15x8's for my 70 Charger. Think 255's will fit all around?  :scratchchin: (0 offset so assume 4.5" backspace, vendor knows it's for my Mopar.)
darbgnik
I have 255/60R15s on the front of my 70. They fit fine. And look right.
Brad
