Help w/Reverse Lights
Started by Evoking, June 29, 2017, 06:11:02 PM
Evoking
Hi all, the reverse lights on my 68 do not come on.  New bulbs do not fix.  Is there a connection under the hood or dash that I can check?
white
If you have a center console there is a reverse lamp switch connected to shifter under the indicator plate, column shift there is a switch on the column close to the firewall, both have a white wire and purple wire if it has factory style wire harness. 69 and later the reverse lamp switch is on the transmission. Hope this helps.
Evoking
Thank you!  Will take a look.
The column switch is activated by a plastic pin (PN# 2883211)  that's well known to snap off.
