rear gear oil
Started by 68restoration, August 09, 2017, 05:56:25 PM
68restoration
Wanting to check the gear oil in the rearend on this 68 charger i'm working on.Its a single traction rear. Are these like most other rearends were you just remove the large plug on the side and stick your pinky finger in the hole, and if the fluid touches your finger, its ok ?
BLK 68 R/T
Yes, factory spec is level to 1/2 inch below the hole on the 8 3/4 and Dana 60.
68restoration
Small hijack here...
I pulled the axles on mine and after sitting in the closed garage overnight, the old oil sitting in the tubes is really stinky. Is there an easy way to get the old oil out without cracking the seal and should I flush with something before refill?
BLK 68 R/T
Quote from: Dino on August 10, 2017, 07:46:03 AM
Easiest way is to just suck it out through the fill plug with a hand pump. As far as flushing it, I would just fill it with new oil and run it for a while and drain/refill again. Examine the oil you suck out and see how much crud is in it and maybe another drain/refill would be warranted depending on what you find. Also don't forget to add sure grip additive as applicable to the oil.
Quote from: BLK 68 R/T on August 10, 2017, 10:06:12 AM
Great thanks!   :cheers:
No sure grip here.
People think I'm nuts but when I want to drain an 8 3/4" I drill a 3/16" pilot hole in the bottom of the housing about an inch off center and let it drain. After in drains thoroughly, I enlarge the hole and tap it to 1/8" NPT and install a socket head plug. I coat the drill with heavy grease to trap the drill shavings.
alfaitalia
Good idea. On my Jeep the PO had fitted a dif cover with a drain plug...made my life a lot easier. I'm not sensitive to smells of most types...but diff oil is the exception.....a truly horrible smell, even when new! I use disposable gloves and get rid of the old stuff as soon as possible. I find that if I get even a tiny bit on my hands I can smell it for days after!
Bronzedodge
Quote from: John_Kunkel on August 10, 2017, 01:52:20 PM
That's perfect.  An 1/8" plug has enough threads per inch to be secure in the (relatively) thin housing.
M B   (pipe guy)
Mopar forever!
BLK 68 R/T
I like the idea as well  :cheers:
Daytona R/T SE
Excellent idea.
Can you post a picture of where exactly you placed the hole/plug ?
Would it be damaged by a floor jack placed under the housing?
