Disc brake booster
Started by q8charger, August 24, 2017, 03:12:51 PM
q8charger
Hello ,
 I just know The booster is mounted upside down for my car 1969 charger . I bought Disc brake  kit   :'(  this is My mistake . The check valve should be facing up and toward the engine. Right Now I don't know if the booster is damaged !!!   , still I didn't started the engine and i only pushed the brakes pads to get Air out off .
Right Now anyone know if the booster is damaged ??? ?
BLK 68 R/T
I can't see how having it upside down would make any sort of difference. Flip it over and see. Even if the booster quits working, the brakes will still work as long as they are in good working condition. Although the pedal effort required will increase quite a bit.
q8charger
Highbanked Hauler
Did you get the disc brakes working  yet ?
92 Cummins Turbo Diesel
04 PT Cruiser
