POSTING PICS AND UPDATES THE RESTORATION AS IT UNFOLDS ON MY 69 DAYTONA CLONE
Started by kevs1969daytona, September 02, 2017, 03:12:28 PM
kevs1969daytona
Ya the dash well maybe a woodgrain upgrade  :icon_smile_big:, the car is on stilts and I just had to buy a new clutch and pressure plate, got the flywheel resurfaced, and the dash being not covered is the last of my WORRIES.  Purchased a new shifter lever from sst (they said I should get a pistol grip, no wrong year) because the one with the Tremec I purchased is straight, got a new brown 4 speed ball from year one, only place on the planet that sells them. anyways the stress is getting well, stressful.
Charger-Bodie
Www.megapartsusa.com sell that shift ball! And a ton on other stuff far more reasonably than year none.
birdsandbees
Okay, I'll stop ragging you about the dash. Just thought I'd save you the $800 for a 5 piece bezel kit and the unobtainium good dash pad prices.
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
kevs1969daytona
Quote from: birdsandbees on May 02, 2018, 09:31:14 AM
Sorry man this thing is consuming my bank account lol
birdsandbees
Then why let other stuff get damaged that is going to cost you more???  :shruggy:
FrnkNsteen
Quote from: Charger-Bodie on May 02, 2018, 09:03:57 AM
Brewers Performance has them too
1969 Charger SE (Just starting the restoration)
1967 Barracuda Notchback
kevs1969daytona
Quote from: birdsandbees on May 02, 2018, 11:44:40 AM
fair enough will get her covered up
Lighthorseman
Say, while you're at it, are you giving much thought to going to power brakes...and possibly front discs?
Lighthorseman
Quote from: kevs1969daytona on May 02, 2018, 06:10:56 PM
Thats too expensive they are $3000 plus
True - and it's also something you can do later, should the muse fall upon you.  :2thumbs:
Aero426
Converting front brakes to any of the 1970 and newer disk setups is not expensive.     This kit offered is the later 1970's style sliding caliper.   Very easy setup to work on.     The kit requires 15" wheels for clearance.
https://www.speedwaymotors.com/1962-74-Mopar-B-E-Body-Front-Disc-Brake-Kit,3793.html
kevs1969daytona
Pressure plate, clutch, and pedals arrived, flywheel resurfaced.
kevs1969daytona
More progress on the car, it was supposed to be done by now, but with all the hidden rust its hopefully August now.  Heres some picks of the rear floor pan area that has been patched.  Asked if I should just get a new rear floor pan Sean said its not that bad just 2 patches.  Got the shifter from SST and the ball from year one.  The shifter was a course thread but the ball was a fine thread.  Took it too my dads place he quickly tapped it out fits perfect now.  The chrome exhaust tips that I was going to replace because they looked like crap were washed and cleaned.  Now look super good saved some money.  Kinda realized got the car in August last year, was at Pro Stock for about 1 month get new motor, been a Clarke Customs since November,  been in a shop 2x more than at home.
kevs1969daytona
Heres a couple of picks of the Tremec 600 TKO picked up in Red Cliff Alberta last week.  Also the rear brake cable which this car never came with.  Think if its going to be a manual might need a parking brake.
kevs1969daytona
Almost finished the rust and body panel replacements.  There will no zero rust once Sean is complete.  Then he sats he stripping the entire car down to bare metal.
moparstuart
Here is the Dakota Roller Bearing you need    Pilot Bearing – Dakota roller bearing – MP#53009180 or custom. Fits large hole, crank drilling for stick is not required. Tremecs all have 3/4" pilot like regular 4spd
kevs1969daytona
cheers  :cheers: just picked one up at local dodge dealer.
kevs1969daytona
BigCE
Awesome build, going to be a cool car when its done.
Nice to see another member from Alberta.  :2thumbs:
kevs1969daytona
kevs1969daytona
Think the nose cone was attached to a modified 70 bumper as per the previous pic
kevs1969daytona
Kinda in a dilemma now, Sean has taken the nose cone apart, ground it down, now he thinks it's a real superbird cone.  Say he can modify it, but thinking it's better to get a fiberglass Daytona cone and save Sean a week of modifications.  Wondering if the it's a real Superbird cone  :shruggy: is it worth much any idea thoughts ???????????????
kevs1969daytona
Also if its a Superbird cone will I need new headlight buckets if a get a new figerglass Daytona cone.   :brickwall:
kevs1969daytona
Fenders have quite a bit of patchs and bondo but not too bad, easy repair Sean tells me.
Lighthorseman
Quote from: kevs1969daytona on May 21, 2018, 06:56:17 PM
Looks like a 'Bird nose.  Now, if I recall correctly, the headlight doors are the same for both S-Birds and Daytonas.  Not sure about the headlight buckets though...but I'll just bet someone will chime in soon.
